Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Help with my front disc brakes
    Lichfield
    Default Help with my front disc brakes
    I'm want to change my front pads on my 03 2.0 dti vectra. does anyone know the size of the drive socket i need to remove the locking pins ?
    Jun 2007
    Black Country
    do you mean the ones at the other side of the caliper?
    if so, i believe its a 7mm hexbit
    Lichfield
    Cheers bud. Do you know how to change the front discs ? After you have taken off the two hexbits and removed the caliper can you remove the disc or do you have to take something else off ?
    Sorry for asking dumb questions
    Portadown, N.I.
    There's just a (5mm) allen screw that holds the disc on to the hub, undo that and then the disc can come off.
    The disc will prob' be stuck on, so if you get a piece of wood and place that behind the disc and then hit repeatedly with a hammer. You might need to rotate the disc around while hitting it to loosen it.
    Tim
    Full Member Big Sig's Avatar
    there maybe a small retaining screw, if it won't come out - usually siezed in - impact driver may help, just drill the head of the screw and remove it afterwards or use it as a locating pin for the new disks
    Lichfield
    Only joined today.....this is pretty good
    One more question - the caliper is mounted onto the anchor bracket, do i have to remove that or can i get the new disc on by simply removing the two 7mm hex bolts and removing the caliper ?. If I have to remove the anchor bracket what size ar the torq bolts ?
    I owe you a drink !
    Portadown, N.I.
    I think you can leave the anchor bracket on, there's another post on here that said you dont have to remove it.
    When I did mine I did remove the anchor bracket as I didnt have a 7mm allen key, I think the torx bolts are E18 or E20, I cant remember which exactly, but I do remember that they were unbelievably tight, and that they need threadlock and torquing up to 230nm.
    Tim
    [Ex]Admin Duncan's Avatar
    You'll need to remove the carriers - 2 x E18/20 bolts which are very, very tight. You'll want a long bar/breaking bar to undo them. Clean the threads and reapply locking compound when you refit.
    Lichfield
    I'm going to change the discs and pads tomorrow so will let everyone know how I get on.
    I haven't got an E18 or E20 torx bolt socket so I hope that I don't need to remove them.
    Does anyone out there know for sure ?
    Portadown, N.I.
    found the thread I was on about,
    http://forum.vectra-c.com/showthread.php?p=484809
    Tim
  1. Disc Brakes
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2010, 21:12
  2. Wh brakes disc and pads do I need?
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2009, 22:50
  3. 314 disc and brakes
    By kenny1zero in forum Handling & Braking
    Last Post: 29th June 2008, 22:33
  4. disc brakes
    By dan1983 in forum Handling & Braking
    Last Post: 1st December 2007, 09:50
  5. Grooved Disc Brakes
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2007, 22:45
