Results 1 to 2 of 2
Thread: 3.2 GSi - smoke under bonnet, BEWARE !!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default 3.2 GSi - smoke under bonnet, BEWARE !!
    Tonight I thought I'd have a look from a distance to see what my xenons looked like. As I walked away from the car, I could see hazy smoke in the headlights.
    ****, so lifted the bonnet and could smell something like burning rubber. Shone a torch around the engine bay and noticed the smoke was coming from the bulkhead area, somewhere by the rear exhaust manifold (V6 remember). The smell was now like oil on the exhaust manifold. The smell was worse when you revved the engine. Never thought I had any oil leaks but found oil leaking from the back rocker box cover.
    "How come" I think, so decide to check the torx bolts on the rocker cover, or at least the ones you can get to without taking off the inlet manifolds
    There were three bolts I could get to easily at the rear, two could be tightened a bit further but the third one was about to fall out!! This would explain that when the engine was revved, oil would be forced out under pressure.
    Tightened all three bolts, no more smell
    Might be worth other 3.2 owners just having a quick check to check for the same before things get worse.
    Belfast
    It wouldn't be a Vauxhall without oil ****ing out of it somewhere.
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. oil smoke from under my bonnet.
    By TimTay in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:37
  3. alrm was going off I turned the key and there was smoke from the bonnet?
    By mycosri in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2009, 19:21
  4. ps3 and beware gta IV
    By howey in forum Games Room
    Last Post: 26th May 2008, 01:05
  5. Smoke under Bonnet after Glow Plug Change
    By vec1975 in forum Engine & Drivetrain
    Last Post: 7th May 2008, 08:25
slight smoke coming up from back of bulkhead area on vectra c
