Thread: Help needed!
    Jun 2007
    Default Help needed!
    I have a 54 1.9 CDTi 150. Last night in the snow I had to brake heavily and the ABS engaged. Then as I was setting off the traction light lit up for a couple of seconds and went off. The next time I had to use the brake I noticed that when I press the pedal I could hear air from the pedal. The brakes work fine and when the enigne is turned off the pedal hardens after a couple of pumps (as per norm). Any help would be great.
    [Ex]Admin Duncan's Avatar
    Traction light lighting up as you set off, given you were on snow, would be normal. The light is simply indicating that the TC system has cut in.
    What do you mean by hearing air from the pedal?
    Jun 2007
    Hi Duncan, thanks for your help mate. It's a bit like a pumping sound. When I press down it sounds like air coming out and when it depresses it sounds like air sucking in. I turned the engine off and stuck my head under the bonnet and asked someone to press the pdeal. I could hear the same 'sucking and blowing' noises but it was too dark to see anything. Hope this makes sense!
    I think it's just the normal sound of the hydraulics. <Goes outside to listen to his>.......
    Jun 2007
    I hope it is, but it is quite noticeable. It is definitely loud enough to hear when the engine is running. And I've definitely never noticed it before.
    Jun 2007
    I've just been out to try it again. It sounds a bit like when you use a foot pump to blow up an inflatable. It's definitely not the normal sound. The actual use doesn't feel any different. Pedal doesn't go al the way to the floor or anything.
    Regular Member WHOOSH05's Avatar
    On the back wheel
    Thats normal you can hear it when the engine's not running.
    it's the noise of the servo working......
    funny you never heard it before the 'incident'.... but that'll be what it is..
    Jun 2007
    Thanks guys, much appreciated!
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
