Thread: It keeps going limp on me!!!
    Lowestoft, on the edge of the world!!!
    Default It keeps going limp on me!!!
    Hi guy's. I found this forum whilst researching a fault with my Vectra C 2.2 DTI SRI.
    Over the last week it's been continuously dropping into limp home mode and i'd also noticed the fuel consumption had dropped although there was none of the black smoke reported by some other members. My friendly Snap-On dealer was kind enough to come and give me a demo of his brand new diagnostic machine .
    He found a fault relating to boost pressure sensor, on inspection in the engine bay i found a vacuum pipe to the EGR valve with a nice hole in it. i've since repaired to pipe and am hoping this will cure my flacid Vectra
    Does anyone know if this would have caused my fault and my subsequent poor fuel consumption?
    cheers folks
    Adam
    the DTi runs a vacumn controlled ( rather than electronic controlled ) system, so any vacumn leaks are bad news on this engine..you'll need to do a 100% repair on it..and if one's holed, check all the other hoses and their rubber connectors..
    the hole would definately cause your EML and limp home mode..if it does it again clean the boost sensor gently with some carb cleaner as it's more than likely got oil contamination in it..don't spray into the sensor directly as you can damage it..
    Default aaah!
    Hi Mark,
    Whereabouts is the sensor and are there any pictures here on the site?
    Adam
    sensor is in the post turbo boost hose...don't think there are any pics on the site.....
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    check the egr vaulve plug at the bottom of the unit as this has happened to me before
    Feb 2006
    Guttedsville
    Boost sensor is down the front of the block, look for a plug with two bare wres coming out of it before it's properly sheathed, Below and slightly left of (towards drivers side) of the EGR Valve housing.
    Cool Ooooh errr!
    Hi folks,
    Thanks for all the help. I'll give it a look first thing in the morning
  1. 2.2 dti limp and cut out
    By ptrehearn152 in forum Engine & Drivetrain
    Last Post: 7th January 2013, 23:45
  2. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  3. Limp mode..
    By ShaunyB23 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2011, 20:37
  4. DTI limp.
    By madman in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 19:15
  5. 2.2 dti limp
    By twaiter in forum Engine & Drivetrain
    Last Post: 6th April 2011, 08:57
