Results 1 to 10 of 13
Thread: draining the water
    member of the smoke patrol 230bhp+
    Default draining the water
    im looking to change the water in the car
    just a quick one
    where is the best place to drain the water from the rad
    lower coolant hose on the radiator..spring the clip off,remove the hose, drain, and replace the hose and clip...
    ...or if you can't be arsed pulling off clips and hoses, just turn the drain tap that's behind the rad on the driver's side.
    Jul 2006
    excellent! Never yet seen Mark bested on anything car-related! And I particularly liked the swear filter evasion...
    ...or if you can't be arsed pulling off clips and hoses, just turn the drain tap that's on the bottom of the rad (well more behind it) on the driver's side.
    i tryed that it didnt drain """ i was gutted the clips are a pain ""
    Didn't drain? It was definitely the right thing you were turning?
    Did you remove the coolant tank cap to allow air in and the coolant to flow?
    dont tell me that now iv uncliped the pipe and flushed it
    Ah, so you mean you didn't unscrew the coolant tank cap?
    i turned it 90 and it stoped
    go on tell me what iv done wrong
    Yeah, it just turns 90 degrees, but what I was meaning was that you'll need to remove the coolant header tank cap in the engine bay to let the coolant flow out properly.
  1. Draining Coolant
    By Lean6 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2012, 21:25
  2. Battery draining
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2011, 23:30
  3. Battery keeps draining
    By ScottR in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2010, 15:08
  4. Draining Oil on a 1.9cdti URGENT!
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th October 2009, 21:22
  5. fuel filter water draining 2.0DTi
    By holtie in forum Engine & Drivetrain
    Last Post: 25th April 2008, 13:43
