Thread: Pic request - retro fit auto dimming mirror
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    Default Pic request - retro fit auto dimming mirror
    Hi all,
    After driving my mates 04 Sri last week I was impressed by the auto dimming feature on his car. I know some people on here have retro fitted them, but I have a couple of questions...
    1. How easy is it to wire in & fit to the windscreen?
    2. Will the in-direct night lighting work?
    3. How will it look on the windscreen from the outside (bearing in the mind the casing is different?)
    thanks
    Sunny Dartmoor
    I fitted one the other week to my 04 vectra,very easy,2 wires to connect,earth and 12v live,take them off the ciggy lighter and feed them up to the mirror,simple as that,will take a photo of mine and post them up....
    Widnes, Cheshire
    So I would have to trail a wire from the ciggy lighter to the mirror??
    Can it not be done from the interior light??
    Oct 2006
    Wellingborough
    Hmm, not quite how its installed when a factory option, as it has logic to only operate when lights are on and when in a forward gear, as well as sending a signal over CAN to the drivers mirror to dip and of course control for the brightness of the INL coming from the dash dimmer.
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    i wired mine all off the roof panel as you have the feeds in there you need eg power earth and a light feed (off the switches as they light up when the side lights are on) so the mirror only dims and lights up when the lights are on
    Jan 2006
    Hornchurch
    dead easy to wire up
    you need to get the reverse wire to it also so it will not dip when you want to reverse
    only 4 wires to do wires on the mirror
    1 Power Fag lighter "Black wire"
    2 Light in the roof so it wont dip when its On "gray wire"
    3 Earth a screw in the roof "brown wire"
    4 reverse wire in pass side loom "white/black wire"
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    can we have a how 2 with a bit of detail cause i'm useless plz plz ill be your friend
    Regular Member Bucko's Avatar
    Pudsey
    OK, how would you go about wiring up the drivers door mirror to do the auto dipping?
    I have one of these mirrors but only have the wires for the heated bit. At least i think it's autodipping as it has a couple of extra wires that go to a plug socket on the back of the mirror and the glass is a slightly different orange/yellow colour and connecting the heater wires to it makes it go dark when you put the heated rear window on??
    Regular Member kns's Avatar
    Northampton
    i am sure theres a how2 on this in the how2 section
    Pudsey
    everything but this one I'm afraid
  1. Can the auto dimming door mirror be retro fitted?
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2011, 08:06
  2. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  3. Auto dimming mirror
    By abbeytec in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2008, 09:20
  4. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
  5. Auto dimming wing mirror info request!!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2008, 19:04
retro fit auto dimming mirror insignia
fitting vectra auto mirror
