Results 1 to 3 of 3
Thread: parrot bluetooth
    crewe
    Default parrot bluetooth
    hi all,
    am trying to fit a parrot ck3100 into my 2004 1.8i vectra but have fallen at the first hurdle.
    Have managed to get the radio out, but have found the connectors that fit into the rear of the unit seem to be fixed into the caddie, have removed the one visible screw in the rear of the caddy thinking that this will allow the caddie to be removed but is not the case.
    I assume that the blue connectors are somehow pushed through the rear of the caddy and then connected to the bluetooth wireing.
    Is there somehow to remove the caddy or is it just a case of pushing them through the caddy and connecting them to the bluetooth from behind the glovebox.
    Also, there seem to be a few loose wires in the bluetooth wire loom that need to be connected to the car, how and where are these fitted?
    Any help in this will be appreciated
    Regular Member DeathStar's Avatar
    UP North
    No....you need the telemute lead for the parrot kit. Qualdlock to Iso to quadlock lead type thing
    All you need to find is the live for the kit.
    I assume you bought the parrot new?
    this chap sells the leads at a reasonalbly price
    http://www.autocomfort.co.uk/
    crewe
    hi deathstar, yea bought brand new, i take it the extra connector will bridge the socket on the radio to the block of 3 in the wireing loom from the car. i assume this missing connector is stopping the radio,cd not work as it all works when the unit is pushed back into the original block of 3 connectors
  1. Parrot bluetooth
    By dunkymunky in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2012, 13:07
  2. Bluetooth parrot help
    By parsco in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2010, 20:36
  3. Parrot Bluetooth
    By n_hudson in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2010, 00:05
  4. Parrot Bluetooth
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2008, 21:42
  5. Parrot Bluetooth HU
    By Spikey© in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2006, 10:50
