Thread: trouble finding reverse gear!!!!!!!!!
    Oct 2007
    cardiff
    Default trouble finding reverse gear!!!!!!!!!
    hi guys
    recently i have had trouble finding reverse gear , i own a 2004 1.9 cdti 120 bhp 6 speed manual,
    the problem is when i lift the gaer lever up and push the gear stick accross to reverse it feels as if something is pushing the lever back towards me making the gear change really stiff ,( and its not a grinding stiff its more of pressure stiff)
    the car still drives fine in all gears and the clutch still feels fine
    any ideas would be great thanks
    [Ex]Admin Duncan's Avatar
    You are lifting the collar on the gear stick all the way up before you try and select reverse?
    Oct 2007
    cardiff
    yeah of coarse ive had the car for about a year
    Sorry, just checking.
    Sounds like the selector linkages may need adjusted then.
    Oct 2007
    cardiff
    is this much work or is it a services type of job, its weird it just happened all of a sudden after a long run
    It's something you can do yourself. It's a bit fiddly, but doable. I don't know how mechanically minded you are.
    The first thing I would do is remove the trim around the lever so that you can get a clear view of the selector linkage and see if there's an obvious reason for the stiffness. If nothing there then look on the engine side to again see if there is anything obvious on the gearbox side of things. You'll see the selector rod clearly going into the gearbox.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Maybe a lube of the cables might help??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Duncan.
    What is the procedure for adjusting the linkage ??
    Dean
  1. trouble finding discs sets on ebay
    By andy_richmond in forum Suspension, Wheels & Brakes
    Last Post: 1st December 2012, 22:42
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. trouble finding a AF33 G/Box for my 04 signum
    By mikaj in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 19:36
  4. Reverse gear
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2007, 15:47
  5. Reverse to 1st gear
    By MalcGSI in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2006, 04:07
i cant get reverse gear on my vauxhall sigum
the col;ar for reverse dont work vectra cdti 120
having problems getting reverse gear on my 05 vectra 1.9 cdti
cant get reverse gear on a signum
Reverse gear for opel coarser
i have a vauxhall sigum cant get reverse gear
2005 vauxhall vectra 1.9 cdti cant get it into reverse gear
2005 vectra 1.9 cdti why is 1st gear where reverse is
vectra f40 cant find reverse
Reverse gear not working Vectra
