Results 1 to 10 of 19
Thread: Auto lights not very auto
    Somewhere I probably shouldn't be
    Default Auto lights not very auto
    My O6 Signum Elite has auto lights, but they are not exactly auto as they just come on all the time..........
    Anybody else have this?
    Regular Member shan's Avatar
    I think you can set the sensitivity a bit lower.
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    theres no setting for the sentitive of the auto lighting sensor,mine were
    always on wether it was sunny or not and also my rain sensor wipers wasnt
    working so i had it in the dealer and it turned out that the wiring loom was
    damaged under the roof lining by the screen,has your car had a replacement
    screen at any point as mine has and it was the windscreen fitter that had
    damaged the wiring,check this out on ya car first then take it from there
    keep us updated
    Just out of interest, where is the light sensor located? I think the windscreen wipers are fine. Although I have to admit, I don't quite understand the principal of them on Vx's. Auto when in intermittent and then also an adjuster to adjust the sensor. Ha ha, not really automatic.
    Regular Member Karl's Avatar
    Sunderland
    its in the rear view mirror bit
    Oct 2007
    Bucks
    My auto lights are the same, they only go off if the sun is shining. If it is overcast but bright they stay on. Wipers also ok.
    Belfast
    Same on the Astra - some days the lights come on when the sun is shining, other dull days they don't come on until it's getting quite dull. Other times they work fine.
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by Raze View Post
    Same here
    May 2007
    south ockendon
    mine seem to work ok, dont come on unless its quite dark or very overcast
    never had a problem with the auto wipers either, now i have had the wiper motor replaced,lol
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Havent got light sensor on mine. I have seen vecs about, going through a short (about 50yards) tunnel, lights came on just as they came out, the car waiting at the junction thought he'd flashed, so pulled out. Luckly the vec stopped in time, and showed him the First letter of Vectre in sign language!
    As for the wiper sensor (which I do have), mine works fine. Havent had an issue with it. As said, could be where the windscreens been replaced and the technician hasnt been that carefull when removing the sensor or cutting out the screen where the loom goes into the roof lining.
    As a windscreen fitter myself, I always check the senors are working first before I take them apart. Had some customers say they wern't working, and turns out, it was the wiring damaged as said.
    Chris
  1. Auto on lights
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 09:54
  2. Auto Lights On
    Last Post: 17th November 2008, 01:58
  3. Auto lights help
    By big nath in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2008, 19:18
  4. Auto lights
    By phil67 in forum General Chat
    Last Post: 28th April 2008, 09:50
  5. Auto-lights
    By Neil in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2007, 10:26
