Results 1 to 10 of 13
Thread: Blanking Egr Vectra-c Cdti 150 54 plate
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Blanking Egr Vectra-c Cdti 150 54 plate
    Hi.
    Had the well known swirl valve issue , Spoke to my Local Vx dealership & they told me to Blank the Egr off. After seeing how much Cr@p was in the manifold i can understand why.
    Trouble is with it blanked off it throws the Spanner light & has a Dtc of " Insufficient Egr flow"
    Now i did not know that the Egr monitored for Gas flow through the Egr on the Vectra !! (Not like the Stilo 1.9 Jtd Egr).
    So to stop my manifold filling with Cr@p again how can i get around this ??
    Can you get an Egr fooler, Electronic Gizmo that plugs into the Egr plug & sends all the happy signals back to the Ecu ?? Or any other alternative ??
    Dean
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default egr
    ive just had the same prob with egr+crap in manifold AA said to put a trade fuel additive/de-carboniser in with the fuel+drive it faster ie not potter as i usually do. i thought the egr put the hot mix back in along with the extra air boost from turbo to give more power as well as a cleaner exhaust mix??
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    How about removing the egr pipe from where it goes at the moment and re-routing to the 'dirty' side of the airbox?,on my 2.2 it went into the plastic inlet manifold so it can't get too hot.
    Belfast
    There's a way of tricking the ECU in thinking the EGR is working while it's disabled, involves a plug in box. I'm investigating how it works at the moment.
    You can also get the EGR disabled if you get a remap.
    I'd love to know how the AA think fuel additive is going to clean the EGR valve.
    Nov 2007
    Staffordshire
    Quote Originally Posted by _ZS_ View Post
    Hi ZS.
    V Interested in the Plug in Box as this would be by far the simplist solution. Where have you seen them ?? I have had no joy searching Etc ??
    Dean
    Tyreman.
    That would work to help remove the Cr@p from the manifold, But the Egr wuld still see no flow & throw a Wobbler
    Dean
    Perhaps the AA man was going to pour it Directly into the Inlet Manifold
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Sorry,i meant if the egr was working ok and it was only blanked off to save the swirl valve,reinstall it first.
    Nov 2007
    Staffordshire
    Quote Originally Posted by tyreman View Post
    No Problem
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The only plug and play cheater ive seen is for the 2.2 petrol, PM Vocky on here, he makes them and sells them for a tenner. With the 2.2 though, if you put the plate on and then you still need to let the egr open and shut so it doesn't throw a fit. It will still be blocked off but the workings still need to work. This can all be done without a cheater. The cheater was only needed when you completely removed the hole system or when the mechanic's of the valve stopped working. TBH, I dont know if it has any relevance to the CDTI valve but I hope its of some help.
    Nov 2007
    Staffordshire
    I'll Send him a Pm
    Then again i won't send him a Pm or an Email as he does not allow either
    Dean
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I'll give him a shout on his main forum.
  1. 1.9 CDTI 150 EGR Blanking Plate
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 19th February 2012, 23:43
  2. blanking plate cdti
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 18:16
  3. Cdti 150 egr blanking plate
    By sebadee in forum Diesel Engine related
    Last Post: 26th April 2011, 19:34
  4. CDTi 150 EGR valve blanking plate
    By bappy in forum Diesel Engine related
    Last Post: 17th September 2010, 16:17
egr blanking plate vectra c 2dtl
blank egr vectra c
https:www.vectra-c.comforumshowthread.php39653-Blanking-Egr-Vectra-c-Cdti-150-54-plate
