Thread: anyone recommend a shortend shock kit?
    Regular Member EURO G's Avatar
    n ireland
    Default anyone recommend a shortend shock kit?
    ive been told that a set of shortend shocks will help to lower the back of my car anyone recommend a set or any feedback welcome
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Shortened shocks alone won't lower your car they'd just cause you problems you need shorter springs & preferably matching shortened shocks
    n ireland
    Quote Originally Posted by Ian S100 View Post
    forgot to say i have 40mm lowering springs already but the back of the car still seems to sit a bit higher
    Mar 2007
    Southport
    You need shorter springs at the back then - you can't lower the car using shocks or the suspension wouldn't allow the car to lift
    n ireland
    can the original shocks not cause the rear to sit slightly higher then?
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    The standard shocks will run a 40mm lower spring height with no problems, you'll need to go for an adjustable coilover if you want to go lower still.
    KW offer 2 coilover options for the Vec circa £650 and £1200 dependant on the spec you want, have a look at Thorney Motorsport website for the KW's
    Mar 2007
    Southport
    No, not unless they've got a spring attached to them - they are just a piston inside a tube filled with oil & damp the oscillations of the suspension
  1. Shock absorbers for a 1.8 sri?
    By chris_sri in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:50
  2. Had a shock last night!
    By maurauth in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 12:31
  3. I'm in shock.....
    By danBoy in forum The 'Off Topic' room
    Last Post: 12th December 2009, 13:05
  4. A bit of a shock!!
    By Jay Kay 313 in forum The 'Off Topic' room
    Last Post: 6th December 2008, 16:45
