Thread: Tyre Pressures 225/40 18
    Regular Member aaruck's Avatar
    Cheshire
    Vehicle : Insignia
    Default Tyre Pressures 225/40 18
    Can anyone tell me the tyre pressures for this tyre size?
    Regular Member littlesxi's Avatar
    Oct 2007
    derby
    they are usually 32 all round depending on which tyres you have on!
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Depends on the model and weight as well, for example standard size (215/50 17) on the 3.2 are something like 40PSI for standard loading.
    For the big engined diesels it will be extra load tyres and quite possibly higher again.
    I would hope your tyre/wheel supplier could help especially if this is a non-standard size for the model of the car.
    Edit: OK your profile is GSi so I suspect you would be on the higer side.
    Alfreton, Derbyshire
    I'm having that size on and I put 32 all around as I checked it with the up-to-date Autodata system. I'm always updated as I work with this system and tyres everyday. Hope this helps mate.
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    32 all round is OK for 1.8 but User Manual specifies 41 all round for 3.2 engine which is in the GSI. Garages and even dealers often put 32 all round on Vectras which require higher pressures. My 2.0T requires 35 all round.
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
