Thread: Oil Light
    Jun 2007
    Black Country
    Default Oil Light
    My oil light has just come on half way to work, how do i check it? i.e. warm or cold, and what oil will i need, it was serviced by the main dealer a while back so im assuming they used the long life oil, i just need to top it up for now as the next service is due in June/July
    3.0 DTi Signum
    I pass a Halfords on the way home so i can get there no problem, but i dont trust there judgement
    cheers in advance guys
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Check oil level cold and on flat ground.
    The light coming on during engine running COULD be bad news. If you lose oil pressure whilst driving, the engine internals may be short on oil, and expensive damage could occur.
    Not trying to shock you, but CHECK IT ASAP, and refill if necessary. Halfords will have a reference for the oil type and certs.
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    check as soon as possible just incase there is a problem, fingers crossed for ya
    Jun 2007
    Black Country
    cheers guys, it felt fine as i drove here, just the light come on, ill go right to halfords tonight and fill up, im hoping its just a tiny bit low
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Oil light coming on is that serious, I'd check it and, if it is low, WALK to Halford's fetch some more.....
    If it's not low, then you may have oil pump problems or an internal leak from the main gallery (rifle) or feeds.
    Jun 2007
    Black Country
    good news
    phoned 2 main dealers
    both have said, as long as its just the orange oil display on screen with NO spanners then its just to let me know to check the oil
    first dealer said 10 40 oil
    second dealer said 3w30, these guys did the servicing from day one so im inclined to go with these
    they also said they can do my cambelt fro £327 all in
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I did my cambelt for £60 iirc for the genuine VX kit.
    Regular Member badge25's Avatar
    Mar 2007
    west midlands
    If it's just the orange light at the top right of the dash it just means it's low and needs a top up. Mine came on the way to paris last year and it needed just under half a litre. It scared the s**t out of me as it aint what you want half way hrough paris.
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Quote Originally Posted by Guyver1 View Post
    Masterfit quoted me £199 for the 1.9 cdti , is ther that much difference for the 3.0 to the 1.9 ?
    Quote Originally Posted by deanos View Post
    yep, two more cylinders! its a bigger job.
    Stick a litre or so of 5-30 fully synthetic in
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
