Thread: Ultra WHITE LED sidelights
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    Default Ultra WHITE LED sidelights
    Hi guys I have a few sets of ultra white led sidelights for sale if anyone is interested?
    I know they will not work on vectra C's, but obvs they will work on other vehicles such as vec B's etc etc. they are 501 bulbs.
    £1.99 and 99pence posted??
    Regards
    Darren
    Jul 2006
    mmmmmmmmmmmm
    Quote Originally Posted by Silver V View Post
    I know they will not work on vectra C's, but obvs they will work on other vehicles such as vec B's etc etc. they are 502 bulbs.
    Regards
    Darren
    They are actually 502 bulbs and look like this
    also have a 800 watt fli amp for sale £65 delivered
    FLi LOADED AMPLIFIER
    Amplifier quality is often overlooked in today's market and in most cases replaced by power. FLI Loaded amplifiers have been engineered to deliver power and also the all important quality of sound that is amplified. Many budget amplifiers are produced to deliver big power, but do so in a raw and often unregulated way. The result is loud but distorted sound that ultimately damages the subwoofers and speakers they power.
    FLI amplifiers are specifically designed to maintain a level of quality at all volumes by delivering consistent power progressively through the range of the amplifiers capacity. This smoother power delivery will significantly increase the life of your speakers.
    Features:
    Loaded 400s & Loaded 800s
    Cast aluminium heat sink for increased surface cooling area, Mosfet power supply, illuminated FLI panel, protective wiring shroud, bridgeable with increased power output, (3 way bridging on 800s) high level inputs, gold 45 degree acrylic terminals, optional remote control, built in protection on overloads and short circuits, built in active hi-pass and low pass crossovers.
    RMS Output 4 x 100 @ 4 ohms stereo
    4 x 120 @ 2 ohms stereo
    2 x 100 @ 4 ohms stereo
    + 1 x 240 @ 4 ohms bridged
    2 x 120 @ 2 ohms stereo
    Max Power 800 watts
    SNR 98 dB
    Frequency Response 30 - 20 KHz
    THD 0.05%
    Crossover type LP / HP / Flat
    Height (mm) 61 mm
    Width (mm) 392 mm
    Depth (mm) 245 mm
    Bass Boost Yes
    HI Pass xover Yes
    Low Pass xover Yes
    Sub Sonic No
    Remote Control Optional
    Type / Class AB
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    slightly off topic but can you get the led bulbs in 24volt? as the bulbs in my truck are a right pain to change
    Jul 2006
    mmmmmmmmmmmm
    will check for you
    thanks
  1. Walsall - Ultra Blue with White Chequered Stickers
    By Vaux-Man-G in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 2nd October 2012, 12:41
  2. Blue/white sidelights (not LED)
    By disco dan in forum Styling
    Last Post: 1st September 2011, 08:24
  3. Ultra Clean Ultra Blue (Pic Heavy)
    By ScotsDragon in forum Quick Photo Album
    Last Post: 27th March 2011, 21:58
  4. Replies: 40
    Last Post: 10th October 2010, 01:51
  5. White sidelights to match HID's
    Last Post: 22nd September 2010, 17:12
