Results 1 to 10 of 13
Thread: SRI owners who have swapped springs Q?
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default SRI owners who have swapped springs Q?
    guys i have the sri and want to help the handeling which is good at min. i have a strut brace so was just going to change the springs for the ones that LMF sell (eibach ones). what i want to know did u notice a difference and did you get your wheels realigned and was it much out.(im really interested in the camber adjustment). i dont want ppl sayn change shocks 2 as i have been told this is a good thing to do and also i couldnt afford nw shocks and i dont need to use coilovers as dont want it 2 low
    spoons
    Guest
    I lowered my SRI with Eibach Springs and it does make a difference yes.
    I would recommend that you get the wheels re-aligned as well. They were out when they checked mine afterwards.
    ... and yes you should get some sports dampers as well, cos that makes another big difference.
    Good luck
    Aug 2007
    Lisburn, N.Ireland
    well dampers maybe another time but thats good it makes a difference. did u do camber toe in etc? and was there enough adjusment in the vectra to get it back to normal or did u need to buy anything else. thanks
    Jan 2008
    North West
    Why does everybody think that the dampers are called shock absorbers?
    Shock absorbers are the springs! this is a fact! I will now wait for you all to tell me I dont know what Im talking about!
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Quote Originally Posted by WillieClark View Post
    Interesting. I don't know what I'm talking about but I would guess that dampers are there to control the movement of the body on the springs, otherwise your ride quality would be seriously compromised. Dampers are there to absorb the shock of encountering bumps and rough services....and are therefore shock absorbers. Springs are undamped without dampers.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    I can see what you're getting at, but this (seemingly well informed) article states that a damper is the technical term for a 'shock absorber': -
    http://en.wikipedia.org/wiki/Shock_absorber
    Sidenote:
    The whole suspension unit i.e. spring, damper etc. is called the "MacPherson Strut" http://en.wikipedia.org/wiki/MacPherson_strut
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Eh the springs are springs and the shockers are the dampers if you go to any motor factor or garage and ask for new shock absorbers you will not get springs as springs are not shock absorbers mate
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    You don't know what you're talking about!!
    Oct 2007
    Bucks
    Troll?
    Jul 2006
    Anyway....
    Yes, I changed my springs for the Eibach set, and to be completely honest, couldn't tell much difference. I don't really drive that hard, so maybe others who throw the car around a bit more would notice a bigger difference.
    Yes - get the alignment checked afterwards, it's only an extra -15mm but that's 50% lower than the SRi springs, and your tyres WILL wear unevenly.
    HTH
  1. Just swapped my 2.2 petrol for 2.2 DTI
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2010, 12:20
  2. This is what I swapped the Insignia for.
    By 67688c in forum Insignia car chat
    Last Post: 20th January 2010, 09:01
  3. Just swapped my insurance over.....
    By PAULMAC77 in forum General Chat
    Last Post: 19th March 2009, 10:56
  4. Any Signum / Vec C Estate owners use PI springs?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2009, 06:31
  5. Swapped the Signum for a Jag.
    By SCOTTEX in forum Detailing and Car Care Discussion
    Last Post: 4th January 2008, 22:57
