Thread: Warranty question.
    Chester
    Default Warranty question.
    If you buy a second hand VX 07 car from a dealer does it come with the VX three year warranty upto 2010 or does it come with a one year network Q warranty only?
    Cirencester
    both. remainder of VX new car warrany and 1 yrs net Q
    The original warranty is stepped
    In the first year almost everything is covered
    In the second and third years there is a mileage limit and the cover, whilst still very comprehensive, has some exclusions
    I've bought several cars through Network Q, and it's actually the balance up to 1 year
    So if you buy a car that it is less than 1 years old in most cases the Network Q warranty never applies!
    If you buy a car that is between 1 and 3 three years old, or more than 60K miles, then the Network Q warranty is more likely to apply
    Furthermore, the Network Q warranty can apply for certain conditions post-purchase
    One of these is if the brake pads fail due to wear and tear, within the first year after purchase
    Under the original warranty you would have to pay for their repair
    However, if you check the small print in the Network Q warranty you will find you can claim!
    Regular Member j13hdb's Avatar
    Nottingham
    Basically the Net Q warranty is far superior- you can get pads,discs,clutch shockers basically everything on it. Vx warranty after the first year is hardly worth the paper it's written on and the dealers nearly always find a "that's not covered" with the normal warranty.
    Net Q states that brakes, clutch etc should be checked so they last at least 1 year. Obviously with the newness of your car a lot of this shouldn't count! Near the end of your Net Q I'd take it to a good garage or someone who knows what they're doing and go over the car with a fine toothed comb!!!
    Chester
    Thanks fellas.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by j13hdb View Post
    ... after the first year is hardly worth the paper it's written on and the dealers nearly always find a "that's not covered" with the normal warranty.
    Not in my experience, you should go to a different dealer, as the current one are cr4p.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    I got a new fuel pump after 14 months - no questions.
  1. Pre warranty run out question
    By KC in forum General Chat
    Last Post: 29th June 2008, 22:23
  2. Warranty Question
    By Mcdermott in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2008, 13:39
  3. Warranty Question
    Last Post: 27th May 2008, 11:33
  4. Stealerships...warranty or no warranty, that is the question!
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 15:48
  5. Vx Warranty question
    By Paulmac07 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2006, 13:11
