Results 1 to 2 of 2
Thread: Engine bay?
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Default Engine bay?
    Hey peeps what products do you use and how do you use them when cleaning the engine bay is it ok to blast it with the pressure washer and is there parts that should be coverd whilst cleaning it?
    Thanks in advance for your replys
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    did mine last summer........so long ago.
    Cover obvious electrical components with cling film double wrapped. Gave the engine bay a low pressure wetting, then sprayed on some stardrops diluted. Used a paint brush to loosen stubborn marks. Wash down carefully with another low pressure hose.
    Allow to drip dry with the bonnet open ( or use a old microfibre cloth)
    Remove all clingfilm.....
    Spray black plastic with WD40 or back to black and admire.
    see http://www.youtube.com/watch?v=h4PeK...eature=related
    stupid comments on there but it does work if careful
    If you are careful with the water there shouldn't be any problem.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
