Results 1 to 3 of 3
Thread: Twin Exit Pipes
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    Default Twin Exit Pipes
    Ok guys, im looking to finally get a set of twin exhausts. Found a new pair off a Signum 2.0T, anyone know how much is involved in making them fit my 1.8Sri? Are the Bore's the same? I'd need a VXR diffuser so there would be 2 cut outs for the exhausts right? Dont want to cut up the bumper!! Any help would be appreciated, I gotta get it right!!!
    Regular Member ACE.TAG's Avatar
    Feb 2007
    hamilton
    Yes you will need the VXR insert mate if your fitting a duplex system and in regards to the size of pipes i would think they'll be the same size if its a standard fit VX pipes but i'm sure someone will come along and confirm this for you!!
    As for fitting them if you look under the rear bumper you should have an exhaust hanger bracket already fitted to hang the exhaust on so it should be pritty straight forward i would think!!
    Regular Member sri22dti's Avatar
    Northern Ireland
    I fitted 2.0turbo vectra dual pipes to my 1.9cdti, the bores are different sizes as you would expect. There is a bit of work getting them to fit, im not to sure if the signum pipes will fit a vectra!!
  1. Twin pipes onto 2.2direct
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2012, 16:32
  2. vectra estate twin twin exit exhaust
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2008, 12:25
  3. twin exit pipes
    By kns in forum Styling
    Last Post: 16th November 2006, 19:08
  4. twin exit pipes
    By kendokiddy in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2006, 22:36
