Results 1 to 10 of 21
Thread: Airbox Mod
    Larkhall
    Default Airbox Mod
    I'm going to order a new panel filter from work to do this mod. I've had a look at the How2 which refers to the 1.9 CDTi, but i'm guessing it's pretty much the same for the 2.2 DTi?
    I also noticed the torx screw under the hose, i know you need to open the jubilee clip to get at it but can you accidently pull the hose out? I'm keen to do this but scared incase i mess it up!!!!!
    It's a piece of cake mate - although my 2.2 was a Vectra B - so it'll either be the same airbox as that, in which case it's really easy, or it'll be like hte current airbox's and the How2 guide will be correct...
    Larkhall
    Mine looks similar to that on the 1.9. If i get it wrong i can always shout for help!!
    south wales
    i did it on my 2.0t if you mean the funnel in side the air box,theres a about 5 torx screws,i took the clip of maf and removed air box with maf,the hardest bit is removing the platsic funnel got mine out and broke a clip but doesn't affect it,take your time,not much can go wrong but wait for more replys cause mines a petrol
    Full Member Big Sig's Avatar
    Yes its pretty much the same, just wip the funnel out
    it's got to be done fella it's just as the 1.9 and you should get good results as i got my 2.2DTi up from 123BHP to 139 BHP just by doing the air box mod and adding a k&n filter !!!!!!
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    Quote Originally Posted by Drinky View Post
    Thans a hefty increase for that mod...
    south wales
    i know on the old vectra v6 the air box is quite restricted,so guessing on different engines will make more of a difference,only my guess though
    Larkhall
    Will it make the engine sound better??
    errrm, no, it will still sound like a tractor
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. Airbox Mod!!
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 14:15
  3. airbox mod
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 14:29
  4. Airbox mod(But Why)
    By stanian in forum Petrol Engine related
    Last Post: 7th May 2009, 09:49
  5. Help with the airbox mod?
    By strothrc in forum Diesel Engine related
    Last Post: 9th April 2009, 15:10
