Thread: Knocking Noise from Front
    Tyneside
    Default Knocking Noise from Front
    Fitted new suspension all round, B4's and H&R springs. Now have a knocking noise which is mostly drivers side, but is coming from both at times. Springseat mod is fitted so only thing I can think of is anti-roll bar links and bushes or maybe put some grease in the seat pan. It was fine then we tightened the top strut bolt and it started.
    Any further ideas? Were gonna look at it later on and see where the noise is coming from.
    Tyneside
    Anyone????
    Checked that the strut has set properly at the top and there fine, gonna get it on a ramp tomorrow and check the anti-roll bar link and bushes.
    Regular Member EURO G's Avatar
    n ireland
    sounds like the drop links maybe were on their last legs and loosening them off done the rest of the damage
    Tyneside
    Hopin so mate either that or it's maybe not set back in the original position and thats causing the noise.
    Regular Member corman's Avatar
    Mar 2007
    hexham
    did you find out what it was?
    Tyneside
    Changed Anti-roll bar links and that solved nothing, after getting the wheels aligned the fella that took it for a drive after said it sounded like the top strut bearings. We had stripped the suspension before and the bearings seamed OK, but obviously once under load they weren't so the bearings were changed and the noise is now gone. Only problem was trying to save all the camber settings etc. so the hub had to come off as well so it was slightly mors work, but all sorted now
  1. Big knocking noise from front
    By waynerl in forum Suspension, Wheels & Brakes
    Last Post: 1st October 2012, 16:54
  2. Knocking/Clunking noise from front suspension
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2012, 17:14
  3. Knocking noise from Front Wheel
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 08:14
  4. Front knocking noise over speed bumps
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 08:25
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
