Thread: scraping noise
    Regular Member dave t's Avatar
    Mar 2007
    Morpeth Northumberland
    Default scraping noise
    I think i need to change my discs & pads front and rear on a 2003 vec 2.0 dti are they easy to change and if so do i need any specialist kit????
    Cheers David
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Got same problem on drivers rear wheel, do i need to change pads and disks to get rid?
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    This sounds like a moisture thing,Basically the pads stick to the disc,on driving of a slight scraping sound can be heard.This disappears as the pads and discs warm and free up.Have a look at your discs,have you got lets say black tide marks running down the discs? My old discs looked like they were cracking! lol especially the rears,not to worry though as these marks are caused by the pads resting or 'sticking' to the disc,....Changed my discs,and fitted green stuff pads,'problem'(not that it really is one but is annoying)solved
    Regular Member ianjofriel's Avatar
    Jan 2008
    Glasgow
    if they are worn down to the cast backing plate, you'll probably start destroying your discs any mile now...
    Jan 2008
    South Wales
    Soz Dave! Cant find any marks on the disk and it still scrapes even when warm?
    Quote Originally Posted by dave t View Post
    Cheers David
    You will need a 'windback tool' for the rear brakes ( avaliable cheaply from ebay) and a 7mm allen key bit.... a E20 and E18 torx soket to undo the caliper mount bracket ( very tight)..a rachet to fit it, a large screwdriver, some copper grease a torx bit to fit the retaining screw for the disc and a hammer to persuade the old disc off..some sandpaper to clean the hub flange up ( very important) and some degreaseant to remove the preserving grease from the new discs..Have a look at the 'how-2's section for the brake pad change thread and it will give you more of an idea..
    Quote Originally Posted by VXR Diesel (180bhp) View Post
    sounds like the pads may be binding...as above, follow the how-2's and strip the brakes. clean the padrest surfaces with a wire brush to remove any crug and reassemble the pads with a ligh smear of copper grease on the usrfaces where the pads touch the caliper or padrest
    Jan 2008
    Dave - if you don't have a windback tool, a pair of long nose pliers will do the job, just be prepared to have to put some effort into it and watch you don't slip!!
    Cheers,
    James
  1. Clicking / Scraping Noise
    By meridian9 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th September 2012, 17:59
  2. scraping noise help please
    By boarderianb in forum Suspension, Wheels & Brakes
    Last Post: 3rd March 2011, 18:18
  3. Scraping noise from rear
    By Benners in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2009, 09:29
  4. scraping noise with brakes
    By dodus in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2009, 20:41
  5. Scraping/scratching noise
    By bruceybonus in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2006, 14:16
