Thread: Design soft ride
    Oct 2007
    Torquay
    Default Design soft ride
    Hi VX drivers,
    Please help me with a soft ride problem on my (56) Design 1.9CDTI 150 Estate. It suffers from the "Boaty ride" feel that other drivers have mentioned. I use mine as a Taxi in Torquay, so I need a good ride, what with all the hills and lanes etc! I do a lot of motorway as well.
    Reading other posts, it seems the problem is the Dampers, not the coil springs. What would be the best thing for me to do, a decent set of Bilstein sport dampers on the rear as someone else mentioned ? or do I have to change all four? I still need a comfortable ride for my customers, will it feel like the SRI for example?
    Any information will be helpful, part numbers/links to sites etc!
    Simon
    (sorry about the essay)
    it won't handle quite like an SRi, but Bilstiens will definatly help..they are much better than the standard VX dampers..Try one of our approved traders LMF ( in the approved traders section ) will sell you a set..
    2 or 4 dampers?.. the rears will help the bouncy feeling and lazy cornering.. but changing the fronts as well will also help no end..
    Cirencester
    thread hi jack:
    how much difference to ride and handling would Eibach Springs make over my SRI springs and design dampers?
    end hi jack:
    a massive tightening and no nose droop under heavy braking..
    Cirencester
    so say when i bang it round a round about you get the feeling of understeer and like the front left wing is grinding on the tarmac... will it improve that? and also on rapid changing of direction at speed on say twisties?
    cheers Mark
    Hertfordshire
    Just a note to say be careful if only changing two shocks if you are changing brand, personally I would advise against this.
    You can never be entirely sure how mixing dampers would affect the handling, it could, potentially, be dangerous. It may cause unexpected handling characteristics.
    If you fit any kind of upgraded dampers (or springs) do them as a set of four, not just one end.
    Full Member izonoky's Avatar
    Aug 2007
    London
    I love the handling of the SRi, I too often take it for granted that all vecs handle the same.
    2.2 Direct SRi
  1. clutch has gone very soft
    By carl bear in forum Engine & Drivetrain
    Last Post: 13th September 2012, 15:48
  2. Design Ride height
    By Ben50n in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2012, 19:20
  3. Are cops too soft.
    By Gr4eme in forum The 'Off Topic' room
    Last Post: 5th March 2008, 15:05
  4. Am i getting soft in old age?
    By Devil Nev in forum General Chat
    Last Post: 29th December 2006, 21:21
  5. Another soft idea!
    By Phatty in forum General Chat
    Last Post: 25th January 2006, 15:35
