Thread: No boost
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Default No boost
    Hi on my 2.2DTi i have had the spanner light come on and have lack of boost, happened a couple of times any ideas ?
    Hertfordshire
    First things first, have you checked all the boost hoses, they are well known for splitting ?
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Will check tomorrow in the daylight
    Hertfordshire
    The thread here, talking about replacements, shows which hoses, hose 1 is more common, but hose 2 goes as well, and it is usually somewhere out of site, so have a damn good check/feel underneath them. (and yes it is easier if you take the plastic engine cover off, just three torx bolts)
    Regular Member Durk's Avatar
    Aug 2007
    N. Ireland
    Mine did this too. it went from new boost hoses, to new vacum pump, turbo and a ecu upgrade. Has done it a few times since but i'll live with it. Tho hoses are the most common
    Aug 2007
    N. Ireland
    It may be the smaller vecum ones at the back of the engine?
    south wales
    it might not be boost mate my dump valve broke and spanner light come on and went into limp mode,i nearly bought a turbo cause it felt like no boost,i just got a hint of turbo low down but check pipes any way but i got mine on computer,felt like i had no power,mines a 2.0t though
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Did you have any luck with the samco hoses from regal ?.
    Hertfordshire
    Quote Originally Posted by Daywalker View Post
    Nope, I am still updating that thread when/if I get any further, as I last said at the end of that thread, they have not replied to my last emails, so I have to assume work is still in progress.
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
