Thread: damaged air con compressor
    Oct 2007
    LINCS
    Default damaged air con compressor
    Hi does anyone know if the condenser is covered by network q warranty.Wife hit a pheasant today and it pushed centre lower grill into condenser damaging condenser, but air con does still work.
    Regular Member jonesy_ni's Avatar
    Co Antrim
    Cant see it being covered if its damaged by hitting something mate
    it is covered under networkQ, BUT..as it is accident damage it will have to come off your car insurance.. networkQ won't approve any repair as it's not VX's fault..
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Damaged mine a while back. VX quoted £500 to replace.............
    Sourced a new one from this company....http://www.adrad.co.uk/new/catalogue...?make=VAUXHALL
    Fitted it myself and got a local garage to recharge it.
    If your is still working then you need a garage to remove the gas as its illegal to vent into the atmosphere. Easy fitting remove bumper, bolt top and bottom and remove.
    That was the reason I found this site and its cost me hundreds since then......
    Oct 2007
    LINCS
    thanks for advice will check out that link cheers
    Why replace the condensor if its only damaged? as long as its not leaking or causing problems, why fix it???
    Oct 2007
    LINCS
    Attachment 6564
    Hre is a pic of my damaged condenser . i have sprayed leak detector on it when air con is on and no leaks and condenser is getting warm as it should so i wiil leave it and hope it does not leak.
    Thats what I would do
    Jun 2007
    in a white box
    Nothing wrong with that condenser. Just need some dead flies and it would be perfect.
  1. A/c compressor
    By andyd in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2010, 11:18
  2. air compressor
    Last Post: 18th November 2009, 07:56
  3. my new compressor :-)
    By big rich in forum The 'Off Topic' room
    Last Post: 16th April 2009, 14:22
