Results 1 to 10 of 11
Thread: Gunson 4142 dwell angle connections - HELP
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Gunson 4142 dwell angle connections - HELP
    Anyone know what connections need to be made to the coil, earth, power etc etc to measure the dwell angle on my other car (V8 engine)?
    My mate has leant me his multimeter with this function, as mine doesn't have it.
    Before anyone states the obvious, it isn't for my Vec
    I've already set the points with a feeler blade and got the timing right, engine runs OK, but just want to check via measuring dwell to be doubly sure.
    He can't find the instructions, and I don't want to blow up his kit.....
    Regular Member DeathStar's Avatar
    UP North
    The red lead goes to the points side of the coil (negative terminal) and the black clamps onto any good ground point on the engine.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I suspected that, but wasn't sure.
    Thanks for the info.
    UP North
    I wish my other car had a V8 engine.....mine is a MK 4 spitfire
    I assume 4 sets of carbs to nicely balance
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No, just twin 1 3/4" SU carbs.
    I do like the Spitfire though, but only having 2 seats isn't really practical for us..
    Why did I mention practicality ? ? ? Since when has a V8 been practical these days??
    UP North
    Thats the problem I have now, since the daughter has been born. Only done about 100 miles in it!
    thinking about getting the luggage rack for the boot and creating an ISOFIX bar so I can put the cat seat on
    Good old SU's 1 1/4" in the 1.3 Spit - Good old hose pipe to set the hiss right for the balance...lol
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Hose pipe hiss, lol.
    Best way is to have a tap in at each carb, connect rubber tube to a 'U' half filled with water and when each are balanced, the water level should be equal in each side of the 'U'.
    OR, get a Digital Delta Pressure sensor to set them up evenly....
    But the hiss from a hose pipe works too, just a bit agricultural.
    UP North
    yes, the manometer type way is always reliable also
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Just to complete this.
    I connected the black to earth and the red to the points side of the coil, and with the engine running the meter showed the dwell angle.
    The book says 26-28°, so being anal I adjusted it to 27° via the adjustment screw on the side of the dizzy. When first connected it showed a dwell of 20°, and as I adjusted it, the engine tone and running improved surprisingly.
    So, thanks DeathStar
    Nicking Ya Dinner.
    LOL, I've got one of those in the garage and a timing gun that looks like a Klingon gun.
  1. Gunson Eeezibleed
    By conman in forum Handling & Braking
    Last Post: 14th December 2012, 20:05
  2. Angle Eyes
    By harley270906 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 21:14
  3. What is the angle of
    By lizard in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 20:47
  4. Cap/Seal combo - Gunson Eezibleed
    By snapsnap in forum Handling & Braking
    Last Post: 26th November 2009, 13:52
  5. different angle
    By savage. in forum Diesel Engine related
    Last Post: 25th April 2009, 17:11
