Thread: Map reading lights - Buttons wrong??
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Map reading lights - Buttons wrong??
    Is it me or are two of the buttons the wrong way around on the map reading lights?
    If you look at the two middle buttons, you have the normal graphic that's on the normal lights (the one that looks like the sun) and one that looks like a power switch.
    On mine if I press the power one the light goes on/off, and if I press the other one it stops the light coming on when the doors open.
    To me these are the wrong way around... has anyone else noticed this or is it just me (or maybe I have a reject unit)?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by lofty69 View Post
    On my car the sun switch one is a blank and with respect to your picture, there is nothing wrong.
    If you sit in the driver seat, in order of buttons going towards the passenger it should be:
    Driver reading switch, sun switch, On/off and passenger reading switch.
    Gazza4
    @home
    Engine : 1.9 CDTi
    It's not the order of the buttons, it's more how they work.
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    mines the same thougt the same but got used 2 it
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    LOL, yes mine are the wrong way round. The outer buttons do as they should but the two middle ones do the other one job.
    @home
    Engine : 1.9 CDTi
    good to hear it's not just me, anyho, got fed up with mine and swapped them around
    If you want to do this (NOTE this very fiddly):
    1) Remove the unit
    2) Using a small screwdriver prise the buttons out gently (ensure you don't loose any of the two metal bits inside the button).
    3) Using the screwdriver, remove the plastic covers of the buttons so you're just left with the black bit
    4) Insert both black pieces back into the unit keeping them upright as you do it.
    5) You should notice there are guide holes at the sides of the button holes for the covers to slide into. You made need to break off one of the sides of the tabs on the button covers for them to fit back into when you swap the buttons around, you wont see this when they are back)
    Sunny Dartmoor
    Will check mine when it arrives,thanks for the up......
    Regular Member cameraman's Avatar
    Leicester
    Mine doesn't even have the button to turn off the lights when the door is opened, (has the map lights) must be a facelift spec-cut, had them all on the pre f/l
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by cameraman View Post
    Yours is the standard upgrade mate. The one with the 4 buttons is the police spec upgrade.
    south wales
    i only have two one wich turns lights off when door is open and other power on off,mine are in the right order mines 53 plate,power button turns lights on off,sun turns off when door open
  1. Boost gauge reading wrong?
    By Steven in forum Vectra C / Signum Troubleshooting
    Last Post: 11th March 2012, 12:11
  2. Map reading lights for a Vectra-C
    By merikiito in forum Parts for sale
    Last Post: 26th October 2008, 16:57
  3. Map Reading Lights & Sunglasses Holder
    By lofty in forum Parts for sale
    Last Post: 28th March 2008, 12:42
  4. Interior lights (courtesy/map reading)
    By parkins in forum Styling
    Last Post: 23rd July 2007, 23:28
  5. Map reading lights
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2006, 09:18
