Results 1 to 10 of 15
Thread: i want to lower my sri more than standed
    Jan 2008
    COOKSTOWN
    Default i want to lower my sri more than standed
    my vectra has the xp kit and 19" i was looking to lower it has anyone ever don this?? how would it look with eiback springs?
    Regular Member shan's Avatar
    I think you will get another 15/20mm on Eibachs. A lot of people here have done it. I'm sure they will post up.
    yep Eibachs are -30mm from standard, so as the SRI is already -15 you'd get another 15mm drop..
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    what would the ride quality/ handling be like? i have the sri as well on 17 at min but will change to 18 inch wheels soon. also can you change the camber caster, toe in etc on the vectra to get everything to line up again.
    yes, the vectra can be adjusted so that everything is fine again.....
    the ride is firm but not harsh..it handles beautifly on mine ( -30 eibachs and 18") i goes just were i point it.. no nose dive under braking, better lines through corners etc etc...best mod i ever made....
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Are you still running standard shocks Mark??
    Aug 2007
    Lisburn, N.Ireland
    thats good. can anywhere do the adjustments. i mean a large type company as im in n.ireland. also where so i get the springs. they will suit the sri suspension ok?
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    The Eibachs are superb in every way.....Bar One...
    My only criticism of them is they do not lower the car enough for my liking, only 15mm on an SRi isnt enoughh, but if you can live with that, then they are simply the best springs you can put on a Vectra.
    Quote Originally Posted by pricey View Post
    yes, standard GSI dampers and they're fine after 25,000 miles..
    Quote Originally Posted by aerodynamic18 View Post
    try www.alignmycar.co.uk for the setting up again, i think they cover N.I.....
    for springs..try 'roadrunner' or 'lmf'.. both around £150...both will sell you a set for your car..all you will need to know extra is the axle weights which you can find on the black sticker on the drivers door plate..
  1. any1 got a gsi standed air box. for sale
    By buckygsi in forum General Motoring Chat
    Last Post: 9th March 2012, 19:06
  2. lower my car please
    By the hen in forum Photoshop section
    Last Post: 21st December 2011, 11:45
  3. Replies: 21
    Last Post: 30th November 2009, 22:21
  4. Lower. Y Or N ???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 20:11
