Thread: Blinking sat nav screen !
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Blinking sat nav screen !
    Hi all, i'm not sure if my sat nav has always done this,
    but i have noticed when using the nav, as the map
    follows your progress or as it refresh's your position, the
    white road names and some road lines blink ! is this normal ?
    now i have picked up on it i carn't stop seeing it ! ( if you know
    what i mean )
    cheers
    Kcs
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I think it is normal; I suppose this happens when you have a big map scale and you've probably choosen to have your position in the centre of the map in the settings ...
    Feb 2007
    Tamworth
    Thanks, might try a different scale to see if it stops blinking !
    Regular Member Gordon B's Avatar
    Jan 2008
    Washington
    If you go to settings when in the Sat Nav mode you can change the way the map behaves, ie
    Head Up (The map ramains still and the car moves, the map refreshes each time the car gets to the top)
    Centrered (The car remains in the middle and the map
    moves)
    North Up (The top of the map always points North)
    You have to have the Navi active (ie with a route planned) then press settings button to get to the menu.
    You will find that in the Head Up mode the map will not flicker.
    Hope this helps,
    Gordon.
    Feb 2007
    Tamworth
    Thanks GB, will take a look in the morning on the way to work,
    many thanks
    Kcs
    Jan 2008
    Washington
    Pleasure, hope it sorts it for you.
  1. Blinking mirror glasses
    By Shaunandkate in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 13:19
  2. Help. Key in, turn, car is blinking at me and not starting
    By essentialdj in forum Vectra C / Signum Troubleshooting
    Last Post: 20th December 2010, 11:07
  3. Blinking engine light - does it mean anything?
    By stevedee3 in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 10:59
  4. Blinking Engine light
    By BlueRob in forum Engine & Drivetrain
    Last Post: 8th January 2008, 18:29
  5. Blinking Hell !
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2006, 12:48
