Thread: Will these wheels take a 20mm hub spacer/adapter?
    Jan 2008
    Tyrone
    Default Will these wheels take a 20mm hub spacer/adapter?
    Apologies guys for branching off from another thread I've started, can someone with a tad more knoiwledge than I cast ther eye over this arrangement, and tell me of any pitfalls before I jump in?
    It's mk4 Golf wheels (ET- same as Vectra C, I believe) but with a 20mm hub adaptor to bring it round to the correct fitment. (Golf mk4 wheels are 5x100.. nowhere near)
    It might even be 30mm, I must double check. Does this 20-30mm spacing pose any problems for clearance etc?
    The car is going down 40mm also, if that has any bearing.
    Thanks again!
    Nicky
    the main problem is just that..bearings...
    the VX wheel bearings aren't known for their robustness..so placing more load on them by adding a spacer is just asking for trouble..they'll wear out quite quickly....
    Spacers themselves are bad news anyway...never have been a fan of them for anything over 5mm ( with longer bolts)..
    Jan 2008
    Tyrone
    Thanks for the input there, mate!
    It's precisely what I'm weighing up, the pros against the cons.
    Pros are: the exact style of wheels I was looking for on the cheap and a hub adaptor set to fit
    cons: now seem to be this bearing issue. I am not a great believer in crazy spacers either (ie: 100mm ones on Chop Shop! ).
    So if I were to embark on a regimen of replacing bearings pretty often, the savings might be negated somewhat.
    Does anyone else have an opinion on 20mm hub adapters, safety, clearance etc.
    Cheers.
    Regular Member EURO G's Avatar
    n ireland
    i think the spacers may bring the wheel to far out and buff on the arch did you see durks post in your other thread about his wheels,nice wheels and they bolt straight on
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Quote Originally Posted by nickyg View Post
    Cheers.
    Yeah, dont do it!!
    Jan 2008
    Tyrone
    Someone's suggested getting the pcd redrilled... anyone ever undertaken this?
    Kinda off the idea of any kind of mental spacing (prob why these adaptors are so cheap!)
    n ireland
    seems like your gonna fit these wheels noo matter what
    Jun 2007
    Quote Originally Posted by stepheng View Post
    If you are that determined to get those wheels on your car, contact the manufacturer and ask them if they will make you a one off set drilled to a Vectra PCD of 5x110.
    Jan 2008
    Tyrone
    Quote Originally Posted by BigMan View Post
    Hee hee!
    Yea it seems I have become one of those January sales types who will plough ahead and buy something, regardless of whether it fits or not. just cos it's a good price!
    Kinda gone off the idea now! It's all good though, advice is what i was after and that's what you guys are graciously providing me with!
    What I think I'll do is spend the extra couple of hundred on the closer size a8 style (replica) wheel and have the bore trimmed a bit to fit and slap it on with wobble bolts. Drop that adaptor idea altogether methinks.
    Bigman, your idea is interesting though. Are you of the opinion that I could get in touch with the sellers of these wheels and they would provide me with a set with th ecorrect pcd. I know some lenso dealers do this but, again, I suppose the issue is cost. I;m looking to get 18"s on the motor and the budget is tight!!
    Thanks lads for all this so far.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i would go with the idea of gettin the A8 rims.
    I use wobbly bolts, an dhave had no problems, would raqther use them than spacers.
  1. 20mm Spacers
    By MOH3B in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2013, 22:57
  2. Wheels bolt length with 20mm spacers?
    By Sharpy28 in forum General Chat
    Last Post: 10th December 2012, 19:41
  3. 20mm spacers anyone?
    By V6 Turbo Elite in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2012, 19:27
  4. Kenwood head unit adapter to Connects2 CANBUS stalk adapter
    By paulw77 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2009, 07:01
20mm hub adapter safe
