Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Fuel Tank Capacity
    Larkhall
    Default Fuel Tank Capacity
    My needle is just above the first red line and i'm hoping it will last till i get paid as i'm going to put Redex Advanced in the tank while it's almost empty then fill it.
    How many litres of diesel does it take to fill the tank?
    Cirencester
    61 from completely empty mate
    Larkhall
    I'm guessing it's the same on both petrol and diesel Vectra's?
    Cirencester
    yupo
    Larkhall
    This redex advanced stuff is supposed to be really good. You have to put it in a nearly empty tank then fill up.
    Jul 2006
    And just for info.....fuel light comes on at around 15 or 16 litres remaining, starts flashing at around 7 or 8 litres remaining.
    HTH
    Larkhall
    Quote Originally Posted by parapaul View Post
    HTH
    Do you mean miles, paul?
    My range says 35
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    oh right, PANIC OVER THEN, so when the light starts flashing you still have just under 2 gallons (2 gallons = 9.08 litres) left in your tank, that would take you on for a fews mile more - No need to worry then!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I read as well on here that when the needle sits in the middle of the red zone the tank is short of empty hence where it says 10miles you have a grace of about 20. Veccys are not as forgiving as other diesels fuel wise. Once you are at 0miles the car is running on fumes and a conk-out is imminent.
    Gazza4
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    HTH
    Can anybody confirm this info?
  1. What is the capacity of the petrol tank
    By peelmeister in forum Reference Library
    Last Post: 27th September 2013, 00:48
  2. What is the capacity of the petrol tank
    By peelmeister in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2012, 08:33
  3. Bad tank of fuel?
    By altitude2k in forum Engine & Drivetrain
    Last Post: 8th December 2009, 14:49
  4. Fuel Tank Capacity.
    By ashdog in forum Engine & Drivetrain
    Last Post: 20th July 2006, 09:45
vectra c fuel capacity
vauxhall vectra diesel fuel tank capacity
fuel tank capacity vauxhall vectra
what is size of fuel tank on a vectra
vectra 2007 petrol tank capacity
vectra c fuel tank capacity
