Thread: VXR Question
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Default VXR Question
    Just curious, I remember reading on this forum about a diesel version of the Zafira VXR was supposedly coming out this year, and subsequently a diesel Vectra VXR, which was to be powered by a 1.9CDTI, bi-turbo which supoosedly produced 200PS, is this true?
    Also another VXR question, I have been browsing the Network Q used car site and found this, along with others like it:
    Vauxhall NEW VECTRA 2.8i V6 24v (255ps) 2007MY VXR
    If you notice at the top it says 255PS, I thought the VXR produced 280PS (276BHP)? Are there two versions of this engine available in the VXR?
    I'm aware there is a 2.8T (250PS) auto, only available on the Elite.
    Gazza4
    Ashington, Northumberland
    Quote Originally Posted by Gazza4 View Post
    ........If you notice at the top it says 255PS, I thought the VXR produced 280PS (276BHP)? Are there two versions of this engine available in the VXR?
    Gazza4
    Basically yes, two variants. bit like the 1.9 CDTi 150 and 120
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Between late 2005 and late 2006 (some 56 plates) the power was 255PS. So therefore some 56 pates and onwards are 280PS.
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    To answer your questions...
    No derv VXR.
    The VXR was initally 255PS during it's introduction MY2006 this can be identified by reading the colour plate on the inside of the drivers door on the B pillar near the door striker. look for either 186Kw or 206Kw (i.e. 255ps or 280ps).
    Basically the cars are the same except some minor engine internals (cam gears), which brought the engine in line with the saab units. The suspension was also revised with long bushes in the dampers and some updated software for the IDS+2/ESP.
    If it is a MY2007 then it should be a 280ps model. However it could also be a late registered car hence the 2007 tag. MY2007 Vectra's production began in August 2006 as far as I know.
    BTW that's some crap photoshopping in the advert!
    Hope that helps.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers, the top speed of the Vectra VXR is 161mph, is that for the 255ps pr 280ps?
    BTW regarding the photograph, I know that's why you should go and see a car!!!!
    Gazza4
    Dec 2005
    In an estate car
    161 standard for both and may touch 170 with a remap...so I've been told.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Still 5th fastest family car according to the Vectra hater!!!!!!
    Gazza4
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
