Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Which Pipe Do I Cut... Blue or Red
    spoons
    Guest
    Default Which Pipe Do I Cut... Blue or Red
    I've got to fit the Turbo Boost Gauge and the instructions are going on about fitting a 'T' piece on the pipe after the actuator ?
    Which pipe do I need to cut and fit this 'T' piece ? The Blue one... or the Red one....
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Eeeni Meeni Mineee Mo
    Sorry Steve, Cant help.
    Regular Member WHOOSH05's Avatar
    On the back wheel
    I would say blue, but i'm sure on of the experts will be on shortly to shoot me down.The blue is the one you would cut to fit a bleed valve, so is it not the same one as it is the only pipe that actually feeds the actuator?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    It should be the one out the top of the actuator
    Cut them both and put on 2 , then you will have the most boost guages on the site !!
    spoons
    Guest
    Quote Originally Posted by Mugualigwian View Post
    Yes.. but whats the 'actuator' .... and I'm being serious
    So it is the blue one then ?
    On the back wheel
    Its the silver thing bolted to the turbo with a rod coming from it.(last picture cylindrical thing on the left with the blue pipe going to it)
    spoons
    Guest
    Quote Originally Posted by WHOOSH05 View Post
    theres loads of silver things bolted to the turbo with rods coming from them....
    Is it the one in the second picture on the left hand side... cylinder type thingy...
    EDIT: lol - just seen your edit to confirm the above...
    On the back wheel
    Between the turbo and the engine lifting point.
    spoons
    Guest
    Whats an engine lifting point ?
    ... Only joking....
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. 2 siggys - one blue the other petrol blue/green motherwell
    By BYGino in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 23rd December 2011, 01:03
  3. blue flame hi flow down pipe for vec c 2.0t
    By tomo41 in forum Petrol Engine related
    Last Post: 31st May 2011, 19:07
  4. metro blue and dodo juice blue velvet results
    By kirky2k4 in forum Detailing and Car Care Discussion
    Last Post: 21st March 2011, 20:15
  5. purple haze or blue velvet on metro blue
    Last Post: 20th March 2011, 20:23
