Thread: Signum - Intermittent fan run on problems
    Jan 2008
    Stirling
    Exclamation Signum - Intermittent fan run on problems
    All
    Signum 2.0 DTI - 87k - 53 plate
    In need of some advice here. Currently have a dead Signum 2.0tdi in the drive.
    Problem: Occassionally with no sense of reason over the past 3 days, when parked with the ignition off, keys out and the car locked the radiator fan kicks in. Can happen after some time parked up
    Tonight, on switching the car off, the fan ran consistantly till the battery and car wer dead.
    On jump starting and taking for a drive the spanner light would come on intermittently for some reason when changing down gear approaching juctions etc.
    Can anyone shed some light on a possible reason before I limp the heap to the nearest vaux dealer for a diagnostic and have the wallet drained?
    Any help would be welcome.
    Regards
    CF
    Jan 2008
    Stirling
    Default Answer
    All,
    Car fixed fan controller unit faulty.
    cf
    Good to hear! I guess nobody could think of what the issue could be as there were no replies - normally there'd have been a few!
    How was it on the wallet?
    Portadown, N.I.
    Quote Originally Posted by cfsignum View Post
    All,
    cf
    Hi there, could I be cheeky and ask how much it was to replace the fan controller?
    I think I might have a similar problem, I hooked my car up to my diagnostic scanner and have an occasional fault light with code P1481 "Fan Relay 1 Signal Open Circuit"
    The spanner light only comes on very occasionally and then goes off pretty quick again.
    Tim
  1. signum intermittent blue smoke and weird temp gauge
    By kevsmit in forum Engine & Drivetrain
    Last Post: 9th July 2012, 18:54
  2. signum intermittent blue smoke and weird temp gauge
    By kevsmit in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 21:08
  3. signum intermittent blue smoke and weird temp gauge
    Last Post: 2nd June 2012, 20:54
  4. Signum intermittent starting problem
    By kildrum in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 22:34
  5. CDTi 150 intermittent running problems
    By JonSRi150 in forum Engine & Drivetrain
    Last Post: 20th December 2010, 14:13
