Thread: my dads car playing up any help appreciated
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default my dads car playing up any help appreciated
    hi my dad has a audi estate 2.5 tdi v6 not a vectra i know but thought id ask incase theres any good diesel mechanics around so here goes
    its a audi 2.5 tdi v6 on a 1999 and it wont run i am getting diesel at injectors if i undo injector while its being turned over it will start then cut out again after 5 secs just will not run for a length of time.no lights on dash have come on.
    any help really appreciated.
    Ashington, Northumberland
    You say you are getting fuel out the injectors when you crack them off as the engine is being turned over, but at what rate? If its just seepage, then there is a problem, but if it is shooting out under immense pressure like you've severed its jugular then that's good. Is it a common rail or FIP engine? Very difficult to diagnose faults like this so need as much information as possible to even point you in the right direction, let alone get it right. . Have you looked at the timing belt (assuming it's belt and not chain) to see if it has failed and jumped a few teeth, therefore knocking the valve and injection timing out (if thats the case, it may have caused internal damage too). All sorts to think about mate. Get back to us with a detailed symptoms report and we'll take it from there. HTH
    leicester
    Trim : Sri xp2
    Mileage : 100000
    thanks the diesel is really shooting out the injectors you can keep turning it over and it wont start unless you crack 1 of the injector pipes then doit backup it will start but only for a few secsthen you have to do it all again it is a timing belt not chain.would i be right in thinking the pump must be ok or it wouldnt be injecting diesel.
    Quote Originally Posted by deano1 View Post
    Yea the pump and the pumping elements sound ok then. When you are turning it over are you getting unburnt fuel being atomised out of the exhaust (will appear white and you can also smell it). This does sound to me like a slipped timing belt with the information you have given. You really need to get the timing case covers off and have a look at the condition of the belt. Any nasty mechanical noises ?
  1. off for dads new car tomorow
    By paulvectrac in forum General Motoring Chat
    Last Post: 15th September 2012, 22:44
  2. My Dads 307
    By jackolfc86 in forum Engine & Drivetrain
    Last Post: 22nd December 2010, 13:32
  3. dads
    By elite lee in forum The 'Off Topic' room
    Last Post: 21st June 2010, 13:55
  4. for all new dads
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 7th December 2008, 06:48
  5. trying my new n95 and my dads new car
    By chrisgettings in forum General Chat
    Last Post: 16th July 2007, 01:35
