Thread: Ticking noise from engine... more so near the injectors
    Cirencester
    Default Ticking noise from engine... more so near the injectors
    Not a vectra problem but a MK4 Astra Coupe SE2 problem
    Z18XE standard engine no mods.
    We have a loud ticking thats coming from the injector/fuel rail area that increases its tempo when the RPM's rise, this has put the spanner light on. we switched it off and on again and now its put the EML on? and still sounds rough.
    Reving it up and switching of the ignition off and letting it stop to a halt the sound has gone so i believe it is not a valvetrain issue as normally associated with ticking.
    Has done it once before about a week ago but a quick on/off/on and it was sorted... now its taking the p!$$
    The car i think still has full power and is certainly not limited to revs at all.
    Help please....
    Ta Muchly
    Jon
    Cirencester
    any one? Mark? Andy?
    without a code, it could be many things.....you'll have to get the codes read ( if you're coming to the Andover meet i'll do it for you there )
    Cirencester
    not gonna believe this..... brother didnt check the oil
    no oil on the dipstick.... done an oil change and drained about 1.5 ltrs of oil
    DICK HEAD
    yeah.... that'll make it rattle..
    Cirencester
    also sorted the EML and emmisions light. unplugged the Lambda Sensor and reconnected and all is well now, cleaned the connections as they where a bit corroded too.
    thanks for the offer of help to Mark
    Belfast
    Quote Originally Posted by jonr View Post
    DICK HEAD
    That made me laugh.
  1. Ticking noise from rear of engine
    By steveyd83 in forum Engine & Drivetrain
    Last Post: 20th September 2012, 21:57
  2. Ticking noise from engine??
    By Gracey in forum Engine & Drivetrain
    Last Post: 31st January 2012, 00:23
  3. Ticking noise v6 cdti engine
    By Critch in forum Diesel Engine related
    Last Post: 9th June 2011, 23:49
  4. ticking noise from engine
    By johnny ni in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 23:16
  5. Vectra C 1.8 SRI engine ticking noise
    By peternotails in forum Engine & Drivetrain
    Last Post: 1st October 2009, 20:25
