Results 1 to 2 of 2
Thread: Clamping brake pipes during pad change
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Question Clamping brake pipes during pad change
    Assistance required please. Is it necessary to clamp the brake pipe and open the bleed nut when changing the pads on rear and front. I thought it was a case of slowly winding back the piston, changing the pads, bit of copper grease, bish - bosh, jobs a good un. But I've read somewhere that if you dont clamp the pipe, you could damage the ABS. Help
    You can do it that way, equally you can do it the other way you said. If you do, just loosen the brake fluid reservoir cap and slowly winding in the piston with the right tool. Some people do it the first way to minimise the risk of flipping the seals, but it's less of a risk of that happening on these brakes as they are double seals.
  1. Brake Pipes
    By st2malo in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 12:46
  2. brake pipes
    By DTi Elite in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2012, 22:00
  3. Brake pipes need replacement.help?
    By Dobs in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2012, 22:46
  4. Brake Pipes.
    By djveccy in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2010, 00:42
  5. Brake pipes pre facelift...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2009, 23:01
How yo change brake pipe in vectra c
