Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: CDC40 Opera Loses Stored Stations !!!
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default CDC40 Opera Loses Stored Stations !!!
    Once the Station has been programed into a location (1 > 9 Etc) I can then switch between stored stations by pressing, 1, or 3 or 5 Etc,
    But once the car has been turned of & locked up for a few hours the Number buttons don't work, The car stereo does stay tuned into the last listened to sation, You just cannot flick between the previously stored ones !!
    AM i missing something !!??
    Dean
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    Sound like the permenant live feed is not connected. This keeps the constant memory after switch off.
    Regular Member DeathStar's Avatar
    UP North
    Thats a wee bug, my old veccy done that and the wifes does it.
    Vauxhall do not know what it is, and cannot fix it.
    I noticed it only does it in winter when it gets very cold. I suspect an EEPROM issue.
    Nov 2007
    Staffordshire
    Quote Originally Posted by DeathStar View Post
    Sounds about right that
    Dean
    Aug 2007
    Leicester
    Mine does this as well - seems to be about a few weeks before it loses them though. It is the latest DAB unit, which is MP3 compatible (2008MY) if this helps
    I finally got fed up of reprogramming it and took it into Marshalls in Leicester this morning.
    They had a look at it and came back to tell me that it is a known fault and that Vaux/Opel are investigating with Bosch (I guess they make the units) about a software update to correct it.
    The guy on the service desk showed me the Vaux Tech info sheet which explained it. He said they would ring up the tech centre on Monday and find out when/if there is a SW update available, and then ring me back with an update. Said no point putting in another stereo unit, as most likely issue would still be there.
    Hope this helps. I'll update when I know more.
    Regular Member Stu14t's Avatar
    Perth, Scotland
    I had the same issue with my CDC40 but only with the DAB stations.
    The unit was replaced under warranty no quibbles at all. and this solved the problem
    Nov 2007
    Staffordshire
    Quote Originally Posted by Jaffatubes View Post
    Cheers All. Kep us updated.
    It does appear to just be the Dab Stations
    Dean
    dagenham
    cdc40 modified radios arriving from eastern Europe in 2 weeks.[4 preset fault] dealers told me they will call when it arrives. yes, only took 8 months . anyone with the fault get on there case!
    Leicester
    My CDC 40 Opera has also suffered from this fault for the past 18 months. When I requested a warranty repair, the local dealer (Drive Vauxhall, Leicester) referred the problem to Vauxhall. Their dealer's service department handed me a copy of a Vauxhall technical briefing, which instructs dealers to await further instructions and in the meantime, not to replace radios under warranty.
    I have enquired about progress repeatedly and the dealer has told me that Vauxhall are still investigating the fault.
    In desperation, I did write to the managing director of Vauxhall Motors and received a letter and phone call from his PA, who told me they could do nothing until investigations were complete. I told her that the continued delays and lack of urgency were unacceptable. I also pointed out that the loss of channel presets had safety implications, because drivers would be tempted to retune the radio manually whilst driving.
    When I threatened to publicise the problem via the Honest John column in the Daily Telegraph, Vauxhall decided to replace my radio "as a gesture of goodwill". The dealer fitted a new radio, which lost all of the DAB presets 30 minutes later. I was not pleased and felt I had come up against the proverbial Brick Wall.
    I was on the point of writing to Honest John, when I discovered this forum, which indicates that a batch of replacement radios is on its way from Eastern Europe. Has that infomation come from Vauxhall? If so, I do hope the info is reliable !
    dagenham
    Apparently the new radios are marked with a blue sticker. This is what the service manger from tony le voir has told me, he has put a order on one 4 me.As soon as it is fitted and working i will let u know.I also hope this is reliable info
  1. CDC40 Opera - DAB keeps losing the stored stations?
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2012, 13:29
  2. CDC40 opera sub
    By barneytravolta in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2012, 18:32
  3. CDC40 DAB opera
    By larrygroke in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2011, 23:33
  4. Cdc40 opera
    By paulcdti150 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2011, 16:26
  5. CDC40 Opera
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2010, 12:43
