Results 1 to 3 of 3
Thread: limp mode/chugging!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default limp mode/chugging!
    the car was fine 1 minuite and duff the next after parking 4 shopping+returning the engine was as limp as a eskimos wotsit chugging + no power,the AA was strugling as no fault code appeared so phoned vx and they told me the dpf/cat would be blocked hence little fumes from exhaust, being a little concerned at this with only 32k on the clock we tackled the egr valve wich was coked plus the little hole on the inlet manifold to wich it breathes was virtually blocked completly a quick clean and a the thrash it is now fine, short cold journeys are NO good for the 1.9cdti so its tessting my patience slightly!!
    Regular Member justyb's Avatar
    wigan
    mine was the same m8 just got a new EGR valve fitted and it fine part no is 55204250 if you can get 1 thou vx keep runnin out common problem?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default egr valve
    luckly the valve is fine it was just the carbon deposits that were causing me problems, its fine now its been cleaned!!
  1. Limp mode
    By irmscher-brett in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 15:12
  2. 2.2 Dti limp mode
    By j88nya in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 21:24
  3. Help please!! Limp mode...
    By scrumpus in forum Engine & Drivetrain
    Last Post: 17th April 2010, 07:21
  4. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  5. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
