Thread: Smell coolant...
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Smell coolant...
    Car was in yestarday for a service. Mechanic noticed he could smell coolant in the engine bay, yet no leeks!!!! Anyone any ideas.
    Also my rear offside tyre is wearing on the inside, bushes and suspension arm checked yet no joy?
    Jul 2006
    Mexico
    To be on the safe side you have to do a pressure test to "see" if there is any coolant lose. On the other hand it could be caused by a leak somewhere on the system no always too visible...as in here
    http://forum.vectra-c.com/showthread...ant+leak+found
    or its evaporating through the cap of the expansion tank....just a couple of ideas to get you started HTH
    Mileage : 55000
    It might leak onto some where that is warm/hot so it evaporates before you can see it.. Look and see if you can see a white "ish" stain from some where that it might have leaked from.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Do you need to top up coolant water bottle, if it is leaking you will need to top up.
    As for tyres get your tracking checked, if your pressures are correct.
    3.2 v6 Signum and loving it
    Mar 2007
    NI
    Thanks lads, I'll have a look. Funny things is I've only had to fill up once in over a year. Running temp hits between 80 and 100 max when idle after a 10-15 mins.
    How much would a pressure test cost?
    Regards the tyres can the rear's be tracked? I thought only the front are done? Sorry if this is a dumb question....
    Nr Cardiff
    I've just found a small leak in my radiator. Couldn't see any evidence of a leak anywhere but the car was losing about half a pint a day on a run.
    Only found the leak as it was damned cold yesterday and saw steam rising from the rad engine side.
    Radweld = job done!
    Good luck.
    Jul 2006
    Mexico
    Quote Originally Posted by Stevie-B View Post
    I think in this car mate both front and back have to be done mate...someone correct me if I`m wrong here
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Tracking can be done on both front and back, think the system is called "super tracker" though it can be expensive.
  1. coolant smell
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2013, 18:16
  2. Curry smell and losing coolant????
    By omega63 in forum Engine & Drivetrain
    Last Post: 11th February 2011, 01:17
  3. low temperature and smell of coolant
    By lilangel in forum Engine & Drivetrain
    Last Post: 9th November 2010, 10:55
  4. I can smell oil...I think !
    By Nicolas in forum Engine & Drivetrain
    Last Post: 7th October 2010, 07:15
  5. Bad Smell
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2007, 20:28
