Thread: High pitched whine from wheels
    Jun 2007
    Kilmarnock
    Default High pitched whine from wheels
    Hi all,
    Seems i'm getting all my problems in one go!! Coming home from work last night i started getting a whine from the front of the car. Stops when i put on brakes.
    Noticed that work had put a lot of grit down in car park due to cold weather. Could some have got caught up in disc/brakes?
    Getting discs/brakes and springs replaced on Monday anyway but wanted to make sure that nothing else could be causing it.
    Thanks for any ideas.
    Roddy
    Jan 2008
    Wales
    Could be your wheel bearing mate, if not how much tread you got on the front wheels? It could be that your running them low which would cause excess road noise. just a thought.
    Jun 2007
    Kilmarnock
    Thanks,
    Tyre Tread is fine. Would noise from wheel bearing stop when i touch the brakes on though? Doesn't seem to be any looseness of wheel. Hope its not bearing, heard thats pretty costly...
    Quote Originally Posted by RoddyKFC View Post
    Thanks,
    You could have a stone trapped. Is it worse or better when you go round left or right hand corners?
    If it goes when you brake I would not have thought a wheel bearing, they are normally a sort of rumble too.
    Jun 2007
    Kilmarnock
    Thanks for replies. Seems to have disappeared! (touch wood) Must have been something trapped.
    Roddy
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i get something simular when going down the farm track at work,there are huge puddles everywhere......once bk on the road all seems fine again
  1. high pitched noise
    By drivemyvectra in forum Vectra C / Signum Troubleshooting
    Last Post: 19th May 2011, 16:40
  2. high pitched woosh noise when letting of
    By daveypower in forum Engine & Drivetrain
    Last Post: 5th April 2011, 19:07
  3. High pitched squeeling sound ?????
    By dannyjpuk in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 19:40
  4. High pitched noise coming from front right wheel?
    By VXR CDTi in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2009, 14:55
  5. High pitched whinning noise.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2008, 16:00
