Thread: False brake light warning
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    21 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    Default False brake light warning
    My GSi (2003) is giving me a false warning about a supposedly faulty left-hand rear brake light bulb. I have tried removing the lamp unit and gently sanding the contacts but it still does it, seemingly at random.
    The brake lights still work. My other half checks it for me and a friend has also had a look and all seems fine.
    Any idea what else might cause the problem? Is it something to do with a possibly non-VX light bulb being fitted? Or is there some other part of the vehicle's electronic system that is playing up?
    It is an irritation rather than a problem but I don't want any further action being taken by the car's computer systems.
    Any clues would be welcomed.
    Paul
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Had exactly same thing over the past 3 weeks and the same bulb with my GSi.
    Yes, I got three people to check it and they all said it was OK. Two days ago, same warning so stuck other half in car to press brake.
    Lo and behold, bulb had blown but the sidelight bulb below it kicks in when the brake bulb fails. I can only guess my mates were looking at what they thought was a brake light but was indeed a side light.
    Have you changed the bulb as a precaution just so as you can rule this out?
    Jul 2006
    Mexico
    Its either a bad contact between the bulb and the holder or the bulbs it`s about to die. Try changing for a new bulb again to see if that cures it.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    When a bulb blows in the vec c another takes over its job, so the bulb will hav3e blown but it will look like it hasn't. There is a spare working bulb in the false reverse light by the way. Also when I looked at my blown bulb it was fine. It drove me nuts for weeks, sometimes the bulb would work and other times it wouldnt. Turned out the filament had snapped off of one end and was intermittently reconnecting itself as the car went over bumps.
    Melbourne, Australia
    So long as the bulb is the correct wattage, fitting another brand bulb should cause no issues.
    An easy way to check the operation of the bulb without outside help is to turn the headlamps on. Then check that you have two red tail lights on each side. If a bulb is blown you'll only see one light on that side.
    21 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    Thanks, guys. I shall go outside now and check.
    Paul
    Preston Area
    apparently, due to the canbus system, it can detect a fault with a bulb before it actually blows and starts putting warnings out... dont know how true this or how it works is as i was told it by the stealers when quizzing them with exactly the same problem!
    Quote Originally Posted by bruceybonus View Post
    The car cannot detect a bulb that hasn't failed yet... but it can detect a bulb that has failed before the driver turns it on. I think the car turns the bulb on very briefly to check for an open circuit. By the way, this feature has nothing to do with CAN bus.
    Preston Area
    no prob.. wasnt sure.....
    11 Post(s)
    I think you mean the nearside foglight.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. My brake warning light is on
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 22:07
  3. Brake Warning Light
    By brotherkennyh in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 17:00
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake Pad Warning Light
    By Stringlabel in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2007, 17:48
