Results 1 to 10 of 14
Thread: play in wheels
    south wales
    Default play in wheels
    hi all newish to site,i have a vectra 2.0t and thers a bit of play in the wheels,when going over bumps in road the wheel will pull left or right,spilt the ball joint and trackrod end seems fine the plays in the bar,you can change the bar from trackrod end to steering rack but would that cure anything or is it a rack i need,a guy from kwik fit with a 1.8 vectra c said his was same and that changing the bar cured it but not to sure about that,would appreciate any replys thanks
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    south wales
    thanks dean mate,track rod inners are those the bars im talking about this website is great cheers
    Nov 2007
    Staffordshire
    Quote Originally Posted by vectrac20tsri View Post
    Yes, From your description, I paid £9.36 Ea for them from my friendly motor factors. Quinton Hazell Part No: QR3298S Rack End. This was on a CDTI 54 Plate.
    Dean
    south wales
    are they easy to fit mate
    Nov 2007
    Staffordshire
    Hi.
    Not to bad of a Job.
    Put car on Axle stands ( Car lift is much better, Only wish i had one )
    Remove road Wheels
    Undo the locking nuts on your track rods (Steering rack)
    Remove the track rod from the Hub assy.
    You can either wind the track rods off now counting turns to get a rough gestimate of where they came from on the rack or wind them off on the work bench once the rack inner assy has been removed.
    Snip the ties on the steering rack gaitors & slide down to gain access to the rack inners, With a good fitting spanner un-wind the rack inner.
    Rebuild the opposite way not forgetting to apply & insert some Cv Joint grease around the rack inners & in the rack gaitors.
    You may also find it easier to move the steering from one side to the other for better access Etc.
    Get the car's tracking Set.
    Once you have seen the replacement parts, All will make sense
    Best of luck
    Dean
    south wales
    thanks for your time mate cheers
    UK
    Dean
    Do you know what size the spanner should be for un-winding the rack inner?
    Nov 2007
    Staffordshire
    Quote Originally Posted by cookie View Post
    Dean
    Typical, I have thrown the old inners away, Else i could of told you for definate,
    From memory, I used an english sized spanner as it was a better fit, But i have two sizes in mind was it 13/16th's or 7/8th's .
    Can you not measure your new ones ??
    Dean
    UK
    Just measured them and it's 36mm but you say an english spanner so thats 1 7/16th I think.
  1. Play in rear wheels
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 4th August 2012, 09:18
  2. Play on rear wheels
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2010, 23:19
  3. play in rear wheels any ideas
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2009, 13:41
  4. Play TV (PS3)
    By ukanalyst in forum Games Room
    Last Post: 19th October 2008, 01:48
  5. Had A Play In A BMW 730 LD
    By Ben H in forum General Chat
    Last Post: 30th March 2007, 16:55
