Thread: Torque Settings Needed Again
    Tyneside
    Default Torque Settings Needed Again
    Right will be changing all the dampers, springs and fitting the 314mm front brakes and need torque settings for all that apply please i.e. Strut, calipers etc.
    Brake disc to wheel hub - 7Nm (but in reality you just nip it up a bit. You'll feel it when it's tight enough. It's only holding the disc in place before the caliper and wheel goes on, not really holding it in place as such.
    Brake calliper retaining frame to steering knuckle - 230Nm (otherwise known as FFT!) Don't forget to wire brush the bolt threads and reapply locking compound.
    Wheel to hub - 110Nm
    Suspension strut to suspension strut dome - 20Nm + 45° + 15°
    I think that's the main ones. Anything else is really just tight enough to what feels right.
    Tyneside
    Cheers D
    Hertfordshire
    Does that mean they are stretch bolts ?
    More often than not does, when you have to turn though "XX°"
    If they are, do not re-use them, replace them.
    It sounds like they are. TIS quotes to use new bolts, so sounds like it.
    Oh, another torque setting...
    Attach suspension strut support tube (2) to steering knuckle
    • Tighten 2x new bolts and nuts
    Tighten 2x new screw connections, suspension strut support tube to steering knuckle, in 3 stages
    Tighten 2x new screw connection 50 Nm
    Tighten 2x new screw connection 85 Nm
    Tighten 2x new screw connection 75° + 15°
    Tyneside
    Right will sort that out as well, cheers guys what would we do without forums
  1. Car Vs Kerb! Torque settings needed please.
    By 19CDTi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 11:54
  2. torque settings
    By punkgsi in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2012, 09:13
  3. Torque Settings
    By lizard in forum Handling & Braking
    Last Post: 21st June 2011, 17:27
  4. torque settings
    By mparks8590 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2011, 14:10
  5. Torque Settings
    By Robin in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2006, 20:43
