Results 1 to 10 of 11
Thread: What activates front parking sensors?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default What activates front parking sensors?
    As the title says really. Surely its not first gear as every time your in a traffic jam they would beep? Reason I ask is I live in a terrace house and parking is a nightmare at the best of times, but next door has just bought a second car so parking is very tight and as I'm a short arse and like the seat nice and low, finding the front of the car is not to easy. I'm looking at an aftermarket kit so dont know if they trigger the same as factory item.
    Feb 2007
    North west
    You engage reverse gear, it activates front as well. If you need front on just select reverse first, not something you do in traffic very often so a good solution.
    Full Member Big Sig's Avatar
    Quote Originally Posted by rob 2.2dti View Post
    Not quite, the bottom left hand blanking plate by the stereo is for the front parking sensor switch.
    Vehicle : SRi
    Mileage : 137000
    Its going to be an after market kit so no stock dash switch.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    ive never switched my front sensors on, they seem to switch on depending on speed as they switch themselves on everytime i stop, both the fronts and rears come on with reverse as mentioned
    Quote Originally Posted by Big-Pete View Post
    yep, park pilot on the signum only works when reverse is engaged..then both front and back work..
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Yep, front and back sensors work when reverse is engaged and also when you push the dash button.
    Regular Member cameraman's Avatar
    Leicester
    As Pricey said, the fronts turn off at approx 10-15mph
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Aftermarket kits work like this.
    Reverse as you'd expect when you select reverse gear. Front's will normally be activated by the brake pedal. They will wake up but if nothing is there to sense nothing will be indicated (visually or audibly). They will usually remain awake for 10 seconds. Or you can get a box to activate them when speed drops to below a set speed (5mph)
    Some kits will interlink he rears to the fronts. My 8 sensor kit when reverse engaged will light up the rear display and wake up the fronts for parrellel parking. As you swang the front in the outside sensor on the front would then pick up the object you were swinging in behind say a parked car.
    Or to be precise in the case of my sensors a fault was found when linked up like this & I was advised to wire front sensors up to an ignition live so they remained awake all the time. They worked perfectly like this.
    Vehicle : SRi
    Mileage : 137000
    Will that be the same as an aftermarket kit? I cant see them having to be connected to the speed pulse?
    EDIT Just seen your post ben, just what I was after cheers.
  1. Anyone got front parking sensors.?
    By montyfert in forum Bodywork & Interior
    Last Post: 7th June 2012, 21:55
  2. Front Parking Sensors
    By war222 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 13:33
  3. Front Parking Sensors
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2009, 02:53
vectra turn off front parking sensor
vectra c speed pulse wire www.vectra-c.com
vectra c front parking sensors
vectra parking sensor switch
