Thread: CD70 Bluetooth (Factory Fit) - Microphone problem ?
    Darlington
    Default CD70 Bluetooth (Factory Fit) - Microphone problem ?
    Hi,
    I'm having a problem with the factory fit bluetooth. Lots of people I call complain that the quality of the call is poor. The quality of their voice inside the car through the speakers is however excellent.
    This suggests that maybe the microphone is at fault. Anyone else have this problem ? Is the microphone located next to the reading lights ?
    Would the problem be solved if I were to use a dedicated cradle with the aerial connection. If that were the case why is the speech into the car excellent as I am still using the blueotooth connection.
    Finally if I used a dedicated cradle for say my own personal phone and not use the bluetooth connection, could I use the bluetooth connection to connect say my work phone. 2 phones connected at the same time to receive calls but I appreciate I would have to select a primary phone for calls out.
    Mike
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    The mic is located behind the panel between the windscreen and the interior lights.
    The quality of the call is less good when driving at higher speeds, which is normal because there is no external aerial when using bluetooth; this can be solved by using the cradle (and the connected aerial)... if a cradle is available for your phone.
    However, a software update for the UHP from march 2007 improved the sound quality a lot on mine (don't know if your car was build before that date).
    And no, you cannot connect 2 phones at the same time. But, in your example, you could disable bluetooth for your primary phone, so that when you take it out of his cradle, you are able to take the call on your secundary phone via the bluetooth connection
    Apr 2008
    Little Sutton
    Default Poor audio
    Hello Please...
    Ive known several cases, where this has been reported...
    In every case the mirco-phone has been replaced, with a first time fix...
    Please note the is a software down load available from the VX stealers...
    There is no reason why is cannot be done under warranty conditions.
    Ask your stealer to perform an "SPS flash program to your UHP module".
    There no reason why you carnt wait for this opertion - it will beifit you as the results will improve the quality of the UHP function.
    Field Remedy: 2206
    Subject:UHP (Universel Handsfree Phone) Control Unit UWA / UWB - Update - The display shows "Phone Save"Models:Engines:Option:Astra-H 2006...,Vectra-C 2006...,Signum 2006...,Zafira-B 2006...,Corsa-D 2007...,Meriva 2006...All,All,All,All,All,Allwith UWA/UWBComplaint:After the SPS programming of the UHP control unit the display shows "Phone Save".Cause:After the SPS programming of the UHP the complete configuration of the control unit gets lost.Production:
    Remedy:
    In case of complaint the UHP control unit has to be reprogrammed with the TECH 2 Application "Program ECU" under usage of input MY 2007 or later. The troublecodes have to be deleted afterwards.Remarks: - To perform the SPS programming of the UHP control unit the TIS 2000-DVD, version 81 or a later version has to be used at least.- Expected download time is approximately 23 min.
    - If the system does not work properly concerning ingoing and outgoing calls afterwards,the SPS programming procedure and the further steps have to be performed again.- A software update for model Antara is currently not available.
    Functional Group:N - Electrical EquipmentComplaint Group:13 - No/Poor FunctionTrouble Code:None
    Good Luck..
    Quote Originally Posted by mickyd98 View Post
    Hi,
    Mike
    Darlington
    Thanks for the reply. I had the firmware upgraded and this fixed the quality issue. People even remarked on how clear the quality was. I had a further problem in thay my nokia 6233 wasn't listing all entries via the cradle (It would via bluetooth !!). The tech advised that a further upgrade was available. He performed this but it didn't fix the call list problem. The outgoing voice quality has now returned to poor...to the point where it is pretty unuseable. I'll print off your reply and take to dealer !
    Mike
    Regular Member cbee101's Avatar
    Apr 2008
    Blackpool
    cd 70 has phone bluetooth?
    Is this on all models?
    mine doesn't.
    Chester
    Quote Originally Posted by cbee101 View Post
    mine doesn't.
    Factory fit option at around £300.
    Andyl has just retro fitted it into his Signum though.
    Apr 2008
    Blackpool
    ahh..ok..thought I was going mad.
    would have been very annoyed..just paid £280 for a sony ericsson kit...lol
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    i cud of fitted the factory bluetooth for that
    Apr 2008
    Blackpool
    Quote Originally Posted by andy.l View Post
    Don't tell me that!!...lol
    stoke on trent
    Hi there i am new to this site, just took delivery of a VXR 280 got the cd70 bluetooth for my phone as factory fitted, but is there a way i can configure the display when a call comes in that i know who it is as every call that comes in says unknown, I have enquired about the cradle but it is not available for the Nokia N95 8gb at the min
    thanks
  1. Factory Bluetooth and Nokia C3-01 - Problem with contacts order?
    By countduckula55 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2012, 10:41
  2. Microphone for factory bluetooth
    By pipamish in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2012, 00:37
  3. Factory bluetooth CD70 disappeared
    By Flaninacupboard in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2009, 18:55
  4. Factory Bluetooth microphone Wiring
    By dieselvec1 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2009, 20:51
  5. CD70 (factory bluetooth) question
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 22:33
cd70 navi mic problem
cd70 microphone problems
ios9 and vauxhall cd70 bluetooth issues
astra h bluetooth mic not working
vauxhall antara problems
Vauxhall meriva microphone not working
vauxhall meriva problems microphone
vauxhall tigra 2006 in car microphone
where is the microphone in a vectra
