Thread: GSi 3.2 timing belt change?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default GSi 3.2 timing belt change?
    At "up to" what mileage or how many years should you change the cambelt on these V6 petrol engines?
    Local VX stealer has just told me 80k or 5 years. My motor's on an 02 plate with 57k on the clock, allegedly FSH by previous owners.
    Are there any other belts or ancillaries that need doing at the same time?
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    I personally wouldn't go past the 4 years and 40,000 mark....also worth bunging in a new water pump cause there're not that dear and why not do the alternator belt as well.......small outlay for piece of mind (or a new engine)
    right..the OFFICIAL book times are 80K or 5 yrs...BUT..
    Having seen the results of cambelt failures too many times i strongly reccomend that this figure is halved to 40,000..a cambelt change is far cheaper than the cost of a recon V6...
    If i was you, i'd get the belt and roller kit on it as soon as you can afford to..the only other 'failure point' is the water pump..they do have a habit of leaking from the gland seals, so as it's the same amount of stripping as a belt, i do them at the same time, they're only another £25 so it makes sense..while the serpentine drive belt is off, just inspect it, and if in doubt replace it, but it should be fine..
    If in doubt, play safe....
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    "Serpentine belt" - AKA the belt that goes round alternator, power steering pump etc.? Squeaks a bit at the moment anyway when cold so would change that as well.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    "Average" price for a V6 cambelt/roller/water pump change, either VX stealer or otherwise?
    right, the kit for the belt and rollers is around £120 dependant on discounts..the pump as above is around £25...add some antifreeze and then it's just down to the labour..allow for 2 hours, but it does take less...
    if you can hang on, there's going to be a few workshop meets in FEB and March where i'll change it for nothing..
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Mark - any sign of these workshop meets as I'm now starting to worry about leaving the cambelt change much longer. Have sent you a few PMs on the subject but haven't heard anything back. Could you let me know by PM?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by gtr1000 View Post
    Bump..............
    Just need an answer really.
    i'll tell the world..Mrs Gsi isn't very well at the moment ,so all i'm doing is looking after her at the moment and not playing with members cars...so any workshop meets are put on longterm hold...
  1. Help :( low mpg after timing belt change
    By tipsy in forum Engine & Drivetrain
    Last Post: 12th May 2012, 19:02
  2. Timing belt change
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 18th April 2012, 11:15
  3. Gsi timing belt change
    Last Post: 1st February 2012, 13:30
  4. timing belt change
    By sri matt in forum Engine & Drivetrain
    Last Post: 3rd January 2012, 18:25
  5. when to change the timing belt
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 12:42
vectra 3.2 timing belt
vauxhall vectra timing belt change cost
vectra 3.2 timing belt change
vectra c gsi cambelt service interval
vectra c 3.2 cambelt
vauxhall zafira timing belt change cost
cambelt change cost vauxhall vectra
opel 3.2 changing timing belt
vectra c cambelt change cost
vauxhall signum 3.2 v6 timing belt kit
why does the timing belt kit on the vauxhall signum 3.2 v6 come with alloy casting
vectra c v6 3.2 timing belt and when to change
gsi 3.2 cambelt change difficulty
vauxhall insignia cambelt change
timing belt change interval vectra zc 3.2
vectra 3.2 timing marks
how much cost timing belt for insignia sri
hours to change timing belt vectra c 3.2
vectra c gsi v6 cambelt kit
cost of timng belt replacement vectra zc 3.2
vectra 3.2 gsi timing belt
cambelt vectra 2.3 gsi
vectra 3.2 v6 timing belt
vectra c gsi cambelt change
