Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: My Swirl Valve Repair for £4.28 !!!
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default My Swirl Valve Repair for £4.28 !!!
    Having found this lying on my Engine
    http://forum.vectra-c.com/showthread.php?t=38787
    And being Spured on & inspired by pete mc (Not as Cheap as yours Pete !! )
    http://forum.vectra-c.com/showthread.php?t=33511
    i went ahead tonight & repaired my Swirl Valve issue.
    I purchased some Unibond All Purpose Repair @ £3.99
    This is Heat & Oil resistant, Bonds all materials & sets in 5 Mins, Can be Rough Handled after 2 Hrs
    All Bit's purchased from Wilkinsons
    I also purchased some Screw Caps Brown (Colour is your Choice )
    I degreased & cleaned the Swirl Bar & then lightly sanded the Black plastic cups on the Swirl Bar Rail, Separated 4 of the Cup part's from the screw Caps.
    Mixed a portion of the Unibond & Glued the Cups to the Swirl bar.
    I then Mixed furher Unibond & applied this around the Cap Cups & Black Plastic on the Swirl Bar.
    I left this to go quite hard for about an Hour & a Half.
    Then lined up all the swirl valves as per No3 Swirl Valve (Counting left from the timing cover) & Fitted it.
    Fitting it was the most time consuming part, It was a right Barsteward to Hold, get in Line & Push, Much Patience required !!!!
    AnyHow, It works
    How long will it last I just don't know !! But it has to be better than lying on the engine
    Dean
    [Ex]Admin Duncan's Avatar
    Nice one! - and where's my credit for pointing you in the direction of Pete's thread?!
    Nicking Ya Dinner.
    rip on VX's part, they know they supplied a sub part, ok if you are under 3yrs or 60k, but they will also know this remedy, but instead will charge £600 for a new one.
    Nov 2007
    Staffordshire
    And of course, It go's without saying (Thats why i did not say ) a BIG THANK YOU for Duncan for moving my Mouse in the Right Direction
    Dean
    spoons
    Guest
    Well done
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Thumbs up
    and thats a well done job as was mine thanks to Duncan although piggin b+q have changed their supplier so sourced a simular rubber elsewere!!! cheers.
    Regular Member mushy2007's Avatar
    Liverpool
    I get that chuggin in the morning but mo limp mode is it possible mine has the same problem?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Quote Originally Posted by mushy2007 View Post
    Sounds like you should be asking your doctor...
    Liverpool
    Quote Originally Posted by lofty69 View Post
    I have but he told me nothings hanging off!!! lol
  1. Egr Valve Repair or Renew
    By vectra19 in forum Tuning
    Last Post: 3rd June 2012, 18:58
  2. swirl valve repair...
    By marshy200 in forum Diesel Engine related
    Last Post: 6th December 2011, 10:54
  3. Egr valve, swirl valve problems etc..
  4. Swirl Valve
    By parsco in forum Engine & Drivetrain
    Last Post: 29th April 2009, 20:47
  5. swirl valve
    By d2sds in forum Petrol Engine related
    Last Post: 5th December 2007, 21:42
