Results 1 to 10 of 30
Thread: Nutron Test #23123 :- report...
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Eek Nutron Test #23123 :- report...
    Stand back from the computer for this one cos it's right up there with the best of my tests and there is a real danger you may fall over laughing! I don't want to be sued if you hit you head on the monitor
    I took the car upto Red Dot and ran it today for my latest test, an LPG conversion! Now the LPG won't actually replace the diesel, it will be used aswell but I will use less diesel and the LPG costs less than half as much.
    So benifits of this are :
    1) save money!
    2) cleaner running
    3) more power!
    The test didn't actually use LPG and the LPG would be more effective because it would be put in after the mass air flow sensor (MAFS). I actually used a Butane/Propane mix and just sprayed it straight into the MAFS. The LPG would go in just after and the temp drop would not be measured by the MAFS so it should push in more air to burn.
    The graph here shows two runs, the first being how I run around normally, with the remap and water/methanol injection. This runs nice and clean and is smooth aswell as powerfull. The second run (the higher) is with the Butane as well as the above and as you can see, it did not raise the peak torque at all. This is good for the gear box and transmission as 280lbft at the road wheel is about 330lbft at the fly. The benifit is clear though, it humped earlier and held the torque much longer through out the range, just falling under 200bhp at 5000rpm! This also runs clean though not smokey as with the box.
    So I will be ordering an LPG kit for about £450 tomorrow and fitting it asap. Hopefully, with it fitted correctly, it will save me some fuel and increase my bhp to 230 without smoking heavily and while keeping torque to a reasonable level.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Nice one.
    Which kit are you getting?, and let us know (as if I need to ask) how you get on.
    What are you going to use as the gas tank?, a cylinder in the boot or a wheel well tank?.
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I've though long and hard and will probably go with a conventional tank in the boot rather than doughnut. Reason being that refilling would be a problem for a doughnut because my boot is often full. I'll be looking for about 30 litres, so I don't run out quickly
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Are the LPG kits easy to fit, or should it be done by a specialist?
    spoons
    Guest
    Sounds good
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    So it's going to work then Damn, that's incredible - I have made enquiries before and I can't find anyone who will do this conversion for a diesel.
    You pioneer, you.
    Full Member Big Sig's Avatar
    After your opening to this thread, I assumed you had lost your eye brows or something!!!
    Nice one nutron, keep it up!
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Karl, I admit what you get up to is way beyond me, but I admire your never-say-die attitude, boldly going where mere mortals daren't.......
    Quote Originally Posted by Hideous View Post
    You pioneer, you.
    oh, it works.... that's why i suggested it in the first place......
    proven right again......
    Get it fitted Nutron..
    Regular Member ion's Avatar
    walsall
    Nice one Nutron, go for it mate!
  1. FAO Nutron: your next mod...
    By Penfold101 in forum General Chat
    Last Post: 6th June 2010, 23:52
  2. Which Car Seat test report 2008
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2008, 15:10
  3. Something for Nutron...?
    By Penfold101 in forum The 'Off Topic' room
    Last Post: 16th July 2008, 12:09
  4. nutron NOS mod
    By chrisgettings in forum Diesel Engine related
    Last Post: 29th April 2008, 17:07
  5. 1.9 CDTi 150 road test report
    By GARY3306 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2005, 22:34
