Thread: Wiper arm actuator disconnected !!
    Regular Member Led's Avatar
    Kings Langley
    Eek Wiper arm actuator disconnected !!
    One of my friends '04 plate Vecta 1.8Ls had this happen to him whilst driving down the A5 in pouring rain - not ideal.
    Anyone else have this happen ?
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Quote Originally Posted by Led View Post
    It allways happens in the rain!! I had this happen to me when it was raining, but it was the Vectra B. I believe the C Veccies can be troublesome in this department as well. Touch wood it has never happened to me.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    If ya think about it, it wouldnt happen in the dry would it??
    Common problem with the linkage, was one of the 2 wipers still working?
    Kings Langley
    Aparantly not - it got slightly jammed and he mounted a grass verge too.
    It's held together now with a tie wrap as a safety measure
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Not sure exactly what blew on mine, but one of the windscreen wipers failed during a downpour last year. T'other one kept working.
    Fixed under warranty.
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    Happened to me last week - passenger side only, but thanks to this forum got it fixed with a couple of cable ties until I can get to the dealers to get it fixed under warranty.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yip happened to mine i'mm going to make a stab and say I bet the driver side kept working though!
    Gazza4
    New linkage required, the replacement is of a better design I believe
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Check out my post
    http://forum.vectra-c.com/showthread.php?t=37639
    Got Vaux to contribute towards my repair even a year out of warranty.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It happened to me as well.
    The drivers sides continued to work for a short while. The connection for the 2 wiper linkages are ball jointed to the drive mechanism on either side. What happened to mine was that the central pin, which is a splined press fitted into the drive arm, had become loose. This then wobbled about, and the wiper arm ball joints separated and the wipers stopped working.
    I could have purchased a new mechanism, however, all that it needed was the central pin welding back in position on the drive arm and the 2 linkage ball joint 'clicking' on after a dab of copper grease applied. I did put a tie wrap around the linkages for good measure, but it's been fine ever since.
    So, not all failures require new parts (if you have the skill and equipment of course)
  1. Radio disconnected now code needed
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2011, 17:34
  2. After i disconnected the battery.....
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 14:07
  3. Disconnected connector in engine ??
    By dinac_cro in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2007, 16:37
  4. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
