Results 1 to 10 of 18
Thread: Add Trip Computer to CDC30
    Jan 2008
    Selby, North Yorkshire
    Default Add Trip Computer to CDC30
    Hi All. I'm new to the site and I've just bought a Vectra 1.9 CDTi Life (120ps), 55 Plate with Full CanBus (Scroll on steering wheel). Picked it up on Friday and I'm very happy with it.
    However, I would like to have the trip/Board computer facilities. I've read through several posts on the site which imply that this is easy to acheive if you have the CDC40 or CDC70.
    If I want the BC, can I just change my 2 line display for the Multifunction Display and then get my Vauxhall Dealer to enable the BC using the Tech2?
    Do I need anything else to make this work?
    Thanks in advance.
    Andrew
    Regular Member Stu14t's Avatar
    Perth, Scotland
    If only things were that simple.
    To be honest I think your stuffed, It will probably take more than a display change and a Tech2.
    Sorry !
    Jan 2008
    Is there any reason for that? I have the BC button on my CD30. I would have thought all the electrics/Loom would be in place. Does any one know where I can find the wiring diagrams for the Vectra C? Is there a Haynes manual available yet?
    Andrew
    Regular Member NealM's Avatar
    Mar 2007
    Cheshire
    Vehicle : Pre-Facelift
    Trim : LS
    Engine : 1.8 Petrol
    See HERE
    Jan 2008
    NealM, Thanks for the link. I've already seen that one though. Mines the facelift model. Built December 2005.
    Anyone else got any input on the Trip Computer possibilities?
    Andrew
    Apr 2008
    UK
    I would be interested to understand why this would be so difficult.
    I'll be be picking up a 08 Exclusiv that has a CD30 radio, having a look at the Vectra catalogue the SRI also has the CD30 (and the same remote display as far as the catalogue goes) and it has a trip computer.
    Therefore I am struggling to understand what has been changed between the two carsapart from a couple of keyboard strokes at programming time
    Or am i missing something here?
    I may just ring Inchcape in Newbury and ask them to give it a whirl and see what they can enable
    Paul
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by paulw563 View Post
    Paul
    the procedure to add the trip computer is exactly the same for a CD30, a CDC40 or a CD70, but it takes at least a Board Info Display (BID), or a Graphic Info Display (GID) and not the small Triple Info Display (TID) with the two buttons.
    If you have the right display, you only need a Vx-dealer who is able and willing to reprogram via Tech2 in 'Infotainment': enable BC, insert the new CodeIndex, disable checkcontrol (because some sensors are not present); (this part was easy until Opel/Vx decided some time ago to change their software, but it is still possible)
    if you have only the TID: it will be expensive because dealer has to change that one to
    BID is standard with BC; GID is standard with CDC40 or with ECC or with UHP (phone) or some CD70; but most CD70 will come with the CID
    Apr 2008
    UK
    hi sig 63 thanks for the message.
    What is the part number for a BID or GID?? and does anyone have an idea how much they cost new from a dealer??
    I have just seen another post on retrofitting the CD70 and hadn't realised how simple it is, now kicking myself for not having bought one on ebay yesterday with colour screen!
    Paul
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    buying CD70's and displays on eBay is a bit tricky, because you are never sure if they have been unpaired or if they match
    the displays are rather expensive and you need your dealer to install them
    Regular Member Sawyer Reynolds's Avatar
    I've got a 56 plate 1.9CDTi (120) Exclusiv with CD30. My headunit has BC but when I press it it says 'No function' ... Is the button just for show?
  1. Trip computer
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2012, 15:18
  2. trip computer
    By jingo in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2012, 21:51
  3. Trip computer
    By dajafu2002 in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2010, 17:49
  4. sat nav but not trip computer?
    By Turbomanrony in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2010, 01:29
  5. anyone added trip computer/board computer?
    By Craig1985 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2008, 02:33
how to enable trip computer zafira 2005
add sat nav to vectra
vauxhall trip computer activation northern ireland
how to activate bc button
is it possible to enable the board computer on a cd30
how do i get my trip computer up on my 2008 vectra c
does my vectra c exclusiv have a trip computer
vauxhall vectra exclusiv 2008 on board computer
activate trip computer Vectra C
vectra c trip computer not working
vuaxhall zafira 2009 1.9 do you have to activate the in board computer to make it work
can you activate trip computer vectra c
installing trip computer into vectra c
trip counter bid vectra c
activating trip computer on vectra with canbus
